  • 1 month later...
I'm not sure draining your catch cans oil back into the engine straight on top of your cams is a good idea,,,rarely have I ever seen clean oil come out of them. They usually have oil,,,water and crud.
Cheers
Neil.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-5484530
  • 1 month later...
  • 4 weeks later...
you want give the engine as much chance 2 keep the oil in it. so by using gravity will help. good idea. just remember you should have a 1 way value between your can and your turbo 2 prevent turbo sucking the oil Out of the can.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-5601816
  • 2 months later...
bad setup. imo.
self draining should have an oil/air seperator that only allows heavy oil to pass back in to the SUMP not the head...
The breather should always be higher than the drain. your drain is higher. Plus your drain goes straight to the intake and the way it's designed pure oil could go that way. not just gasses.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-5696338
ah the purpose of a catch can is to "catch" and then hold oil, moisture and whatever is pushed out of the rocker covers in crankcase ventilation it has to either vent to atmosphere or to the intake constantly so you dont get a rise in crankcase pressure and blow your turbo or cam cover seals, or any other seals for that matter... a one way valve in the hose to the intake pipe pressurise the crank case as you are sealing the motor once the valve is sucked closed by the vacume in the intake pipe.. is not pvc...pcv is under pressure not vacume so it needs to have one way valve or motor will pressurise even more...
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-5712070
  • 7 months later...
Fabrication looks OK the physics side may need some work, don't worry about the idiots and their ha ha posts, the only thing they work on is their own dicks.
Search for some more engine bay photos and threads on oil control.
Keep it up.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-6070946
  • 5 months later...
I used one of these cans on my gtr, the problem that ur friends on here have pointed out is that it can still get oil back into the inlet. I ran this as an overflow tank, and unless ur tank is getting full after every drive to the shops and back it should be fine, they work very well. I ended up running this and then to a vented can to the side, then back to the inlet, if u are running it back to ur inlet be sure to put ur return on a 45degree angle to create a negative pressure in the pipe. anything more and it will not be as effective.
Good job on the welding any way, I hope u made it with baffles.
GL
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-6299048
  • 4 months later...
Cool air and some extra surface area inside will help condense more of the crud.
Put it near the front, and have baffles inside.
I wouldnt want the crud in mine getting back into the motor.
Like Paul said,
Run the breather system as usual with the pcv and have the can in the line that goes to the air intake before the turbo.
So all you are doing is condensing the crappy oil vapour and stopping most of it from going into the intake and being burned.
I read somewhere this vapour effectively lowers your octane level. Bad if you run high boost n stuff.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-6471474
just out of interest why have you plumbed back into the intake facing away from the turbo? i always though the intention was to have it facing towards to the turbo similar to how you should plumb a bov return. i know i might not be correct, but i think it may cause pressure issues. maybe if someone like scotty see's this he might know more, but he has other threads about intake pipe plumbing, seeing as how he makes them.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-6471617
if you have a properly baffled catch can then there shouldnt be much going into the intake pipe. mine points towards the turbo (using standard rubber intake pipe) and i havent seen any oil/dirt etc in the pipe. the catch can has a little bit of oil in the bottom, and due to the proper mesh baffles id like to think theres not much oil vapour making it to turbo.
https://www.sau.com.au/forums/topic/332885-r33-catch-can/#findComment-6473659
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
