have a mate pulling a 2.5lt one down. engine/driveline is already gone.
if you are interested - post up what you want off it. car is in nagoya. bits will load on the next container out.
https://www.sau.com.au/forums/topic/332899-anyone-need-35-sedan-bits/
nick,
1.have that comng already.
2.unsure of colour - its and 03/04 model - front left hit. - will check.
3. do not think its bose. - will check
Son,
I'll grab that. do you want the whole thing?
it is easier if I get he whole shelf. its not really pick a part wrecking as I can ask for various bits but they usually come as an assembly. Basically I get one shot at the car before it goes to the crusher.
Oh ok no worries!
Anyway my car is 2005 S2 sedan and does the 03/04 3rd brake lights are the same?
Maybe going to buy a V35 Coupe Manual.
Its non Navi but top glove box has the blank cover missing from the optional navigation dvd drive - you have this?
Also the gear changer is bit worn, would love to change it to better looking one as the plastic is peeling off - how much for this?
Maybe going to buy a V35 Coupe Manual. Would like to know how much a few things are to replace to negotiate in price.
Its non Navi but inside top glove box has the blank cover missing from the optional navigation dvd drive, its just a big hole atm - you have this?
With the air induction - it no longer looks like this
The grill to collect air is not there and the air box is not there, just has a pod filter on the end of the hose.
Should i care about this?? when looking where the box was you can just see the drain hole..
Also the right hand side window when your in the car goes all the way up and into the sill. But
1. when you open the door the window comes down (as it should) and when you close it, does not go back up
2. when you hold down the button to put window up or down it doesnt automatically do it itself
3. when the door is open the button will not make window go up or down
Do you have the mechanism to fix this? the guy said some japanese parts place near south port quoted him 20-30 to fix...
Oh also the little plastic cover that goes over the screw in the inside left door handle - need that
Edited by R6n350GT
need more detail on the 'gear changer' :)
have a non navi panel - when you buy the car we can talk the sphincter of the universe.
didnt see the rest of this:
1,2,3: motor or calibration. if motor I can get them. if calibration thats easier. again when you get the car we'll talk the sphincter of the universe.
trim item inside door handle - always missing - $5 part from nissan.
Thanks Chris,
Meant to say gear stick knob not changer.
How do we know about what i need for window ?
As for the trim, save me going to nissan can u also get this?
Also for the other question re: cold air induction cover and box, should i leave as is or ?
Be great if you can PM me some prices, just so i know how much i barter with the seller.
Cheers
Edited by R6n350GT
knb would be better off new ex nissan. anything I lay hands on in that area is going to be worn.
I can lay hands on 90% of the small bits on that car. if they are big bits I have to get a mate involved and that costs money.
window is likely to be a motor. since you are in QLD - where?
Edited by Chris Rogers
In Gold Coast, Robina.
For big stuff can come down to Brissy.
Any advice on what kind of price i need to try and save on the car to pay for these fixes?
Glad i got you close by when i start all these mods!!!
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
