SSCC with a few other clubs is running a super sprint, anyone from SAU going ?
Hope its warmer than my last Wakie trip, 0 deg at 0800 with the track at around 4 degrees at 1000.....
Come on 1:10 something..............or at least better than 1.11.8
This may be the last run with the 25 in it, so if it dies I'm not to fussed, Might just get it put on a tilt tray and send it straight to Unigroup for the dirty 30, Ill be like a kid at Christmas.
Skiiiiiiiiiiiiiiiiiiiids
https://www.sau.com.au/forums/topic/332909-anyone-going-to-wakefield-tomorrow/
Bloody rain made Mark scared, LOL.
Best was a 1.14 with lots of sliding 1 x spin and 1 x straddling the chicane at the first corner after I preformed a overtaking move on a commonwhore who was giving me the dirts, I ended up sliding along at speed with the chicane in the middle of the car, front wheels on the dirt and rear on the road, I ended up back on the road spinning around like a bloody ballerina till I finnaly came to a stop, During this I was looking around for the said commo driver but he had found the mud and grass that I kindly left on the corner and speared of into the litter, I later found him mouthing off to someone in the pits to which I put my 2 cents in by saying that, "If you hadent tried holding me back and blocking me trying to pass you down the straight our little altercation would not have happened", his friends giggled and he mumbled something and turned around.
So all in all a great day, hope its dry next time out.
PS Turbo cars go better when the intercooler pipes are connected.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
