I'm just curious what factory options were available back in the day? For instance, my 1994 r33 gtst has a front mount intercooler and I have no idea what brand it is and where it came from. The guy I bought the car off had it imported with it. Is there any chance it came from the factory? I also have impul bucket seats. I know impul are associated with a lot of nissan cars, any chance these came from the factory?
The reason I ask is I want to put on a Apexi pod and it's apparently illegal to modify two cold air intakes in Victoria because it raises exhaust emissions (can somebody verify this?). But if the cooler came as an optional extra i could argue, should it ever arise, that I have only modified one intake (as the cooler would be stock).
Any advice would be appreciated
https://www.sau.com.au/forums/topic/332956-skyline-optional-extras/
GTS-T come from Nissan with a side mount intercooler.
An aftermarket front mount intercooler would have been installed by the previous owner = 1 intake mod in VIC.
So don't bother installing an air pod.
The stock air box and the panel filter inside is decent enough for about 200+ kW's.
Go for a high flow panel filter if you want but the stock one is still fine... Maybe give it a clean if not done so... :D
Your Impul seats would have been an aftermarket item as well.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
