Hey guys,
Recently, I've bought my self a Toyota Hilux - and wow what a change from a Skyline.
Last night I was driving home from Rosebud along the Frankston Freeway (100Km/h zone), and my parents were following me from behind. According to my speedo, I was just sitting on 97Km/h the whole way, although my Dad reckons I was sitting on about 115Km/h. I went past one of those parked camera car things (I spotted it and slowed down to ~95Km/h), but neither the car in front or behind slowed down either. Parents reckons they were all sitting on 110 - 115-ish.
I've only had the car for 2 weeks, and I didn't notice that the speedo was out by so much. (going from a car thats 11cm off the ground to 45cm off the ground is way different!)
My question is - If I did get flashed at 10Km/h over I will lose my license, but is there anyway that I can contest this? Remember I am a P-Plater, and I never speed.
Off the top of my head I only have like 3 demerit points?
Any advice would be great.
Thanks!
Edited by curlyjimbo
https://www.sau.com.au/forums/topic/332985-speedometer-is-out/
I wish I had better news for you, but on a different note...
it's getting to a stage in NSW as well as VIC that whenever one buys a used car, it's wise to check the speedo against a GPS or a mate's car with a GPS - especially if the acquired car has aftermarket wheel/tyre setup with a possible different (ie larger) rolling diameter.
The tyres have been changed - to 32", not sure what they came with though - I bought it like that.
Maybe I should invest in a GPS Unit haha
You might be lucky, and it's your dad's speedo that is out (reading high). I'm surprised you don't have a GPS.
I though of that, but unfortunately his is dead on the knocker :)
I'm getting the vibe that Vicroads wouldn't give two sh*ts about it - and to them speeding is speeding, even though according to my speedo I wasn't...
your speedo was out because of the tyres, and they certainly won't let you off the fine because of that because the tyre size has been increased more than the legal limit (which is only 15mm bigger in vic, and i'm pretty sure that the stock tyres for a hilux are only about 30", so you are 50mm bigger).
unfortunately you are screwed if you do get the fine in the mail because you were speeding due to illegal modifications. unforetunately the old "i bought it like this and it had a RWC" won't help you much. RWC's aren't so much a certificate of legality of a vehicle but of the general safety of the vehicle. also the seller may have put smaller tyres on to get the RWC and then put the 32's back on after it was done. my mate is a mechanic who does RWC's and he takes pictures of every car that he does for that exact reason so if someone buys a car and then comes to complain he can show them how the car was when he did it.
I've got a Garmin navigator, and I also have a Garmin E-trex (I call it my "fekawi meter"). If you want to call round to my place sometime, I can let you check your speedo against the E-trex.
The other thing to do is use the advisory radar speed checks - there's one Melbourne-bound from Geelong on the Princes Fwy, and one at Beveridge northbound. I find the Garmin agrees with these advisorys, and my speedo reads about 2kph under @ 100.
So, does that mean your speedo is ok?
Nuh, it is out by 13Km/h at 100Km/h.
I was shitting myself so I actually rang Vicroads to check if there were any fines on the car (because they can take up to 3 weeks to be sent out to you), and luckily they reported with no fines on the car.
Thanks for you help again mate. :D
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
