I've been doing a bit of reading and the swap seems pretty simple to put my RB26 into a Stagea. I did a RB26 conversion into my GTST in my carport about 8 years ago with little to no info in a few weeks but that eneded up being almost a straight swap.
I found a link to the gearbox swap a bloke has done
http://www.skylinesaustralia.com/forums/Ma...in-t331327.html
I guess the engine will bolt straight in using the stagea mounts and R33 gtr radiator hoses. Not sure on the loom situation but cannot be very hard to diagnose. Theres only a few wires there. Not sure which diff ratio I'll use yet.
The other problems are to do with wheels and brakes.
Will I manage to get my 18x10+12mm P1 QF rims to fit. I don't mind flaring the guards even if it is a fair amount.
Couldn't find any info relating to the biggest rims/offsets you can fit under a Stag.
Just read/saw that 18x10 +22 fit but stick out a bit.
I also have some Circlar 18x9.5 +22/18? pair and can get some matching in 18x9.5 +38. Also have some 25mm spacers. Might be a better option and everybody won't love them so I'd feel safer. Alway get comments at the lights about the QF's.
Do R32 gtr brakes only fit on a Series 1? What is the difference? If it only hole dia thats not a prob.
Are the shocks the same as R33 in the front. I can then fit my 32 GTR front shocks straight in and then modify the R32 GTR rear shocks to extend to the same length as the R33. Are rear 33 shocks the same length between gtst/gtr?
Are stagea exhaust specific or could I mod a R33 or R32 on easily. I've made full exhausts before so if its just a cut and shut I'll use my 3.5. Fairly quiet.
Is there any particular model to focus on buying to make this conversion easier.
Hoping to swap into the Stag
Forged piston RB26 with -5's with PFC etc. Making just under 300rwkw and only needs inj now for 350+
OS giken triple plate clutch and manual box
A/M diff centre. Very tight
100mm intercooler
Oil cooler
Turbo back 3inch dumps merged into 3.5 exhaust
324mm slotted rotors and GTR calipers with braided lines
Revalved Bilstiens for track work.
For the price of selling the GTR shell and all the bit I don't need plus 2 other cars I own I should be able to do this without it really costing me anything, I get my yard back plus a nice car. All wins
If anybody has any links or info it would be really appriciated or know of anybody with nice cars for sale upto/around 10k.
Cheers in advance.
Should be pretty straightforward. Put a 33GTR box in my S1 and mounts fit and resused auto driveshaft no problem. Probably need GTR ecu and loom. Brakes should fit but will probably need to push guards out for 18 x 10 rims.
i have 18 by 10 with +15 offset of my stagea with them still inside the guards
Auto or Manual stagea?
Auto has 50mm wider rear track (cradle) than a manual
Series 1 or 2, big debat which is better
$10K bugdet will find a nice series 1, or cheap series 2
Series 1 has R33 motor, std auto. not as nice interior, could swap to a series 2 if wanted. 12mm front brake bolts
Series 2 has neo motor, worth more, better looking interior, tiptronic auto, 14mm front brake bolts, different front end look, normally factory side skirts and rear wing, 1-3 years newer.
Couple of cheap series 1's on ebay from $6500
Def would have been using the gtr loom and pfc. Makes life nice and easy.
Gareth, dropping running gear into a cheap Stagea is straight forward. Same issues with dropping into a GTSt regarding pipwork and the added issue of converting to manual. Seems straight forward enough though. No need to cut holes in the firewall, etc. It all bolts over.
wait for mikes arrival re:wheels
Mike is a dirty wheel whore :bunny:
That will either be on a RS4 S or an Autech. I run 18 x 9.5 +22's and in the rear of my auto, they don't fit unless you run about 3 degrees of neg camber.
Darren is on the money with the rear cradles. You can bolt in a cradle from a S14/GTR/etc, with the best bet going for an Aus S14/15 rear end as they don't have Hicas.
To start off with, I didn't really like the S2's however, the front end grew on me and I ended up buying one. For a stocker that you don't intend on buggerising around with or you want to keep it close to stock (ie, boost, turbo, cooler, etc) the S2 is a winner.
Neo motor, tiptronic, if you're lucky to find one like mine, it'll have leather/electric/heated seats, touchscreen navi/climate control etc.
Considering you want to make a monster out of a Volvo Hurse, then I would go for an S1. They are cheaper to buy, parts are cheaper than S2 parts (panels, trims, etc) and you'll be wanting to cut it up anyways.
I found Chris and Min's Stag for around $6800-ish 3 years ago. Something like that now would probably go for around 5k. Leaves 5k to spend on go fast bits if your budget is 10k.
I found mine at auction and got Aaron to import it, etc and complied and on the road it cost me around $13,000. This is what it looked like at auction.
Edited by SABBAi
Interesting regarding the cradle Scott. It would be good to just bolt in what I have becuase it already has a a/m diff centre, cusco adj upper arms, braided lines with slotted rotors and whiteline swaybar. I'm guessing the rear strut towers are higher than in a r32?
I've noticed a few cheap stagea's out here but there aren't to many for sale atm. Might just hang out and wait for a bit. If I can grab one for about 5 that would suit me fine.
Thanks for the help boys!
If you intend to use the r32 cradle you will need to fit offset bushes as the 4 mounting stud/bolts in the car different centres.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
