I've been doing a bit of reading and the swap seems pretty simple to put my RB26 into a Stagea. I did a RB26 conversion into my GTST in my carport about 8 years ago with little to no info in a few weeks but that eneded up being almost a straight swap.
I found a link to the gearbox swap a bloke has done
http://www.skylinesaustralia.com/forums/Ma...in-t331327.html
I guess the engine will bolt straight in using the stagea mounts and R33 gtr radiator hoses. Not sure on the loom situation but cannot be very hard to diagnose. Theres only a few wires there. Not sure which diff ratio I'll use yet.
The other problems are to do with wheels and brakes.
Will I manage to get my 18x10+12mm P1 QF rims to fit. I don't mind flaring the guards even if it is a fair amount.
Couldn't find any info relating to the biggest rims/offsets you can fit under a Stag.
Just read/saw that 18x10 +22 fit but stick out a bit.
I also have some Circlar 18x9.5 +22/18? pair and can get some matching in 18x9.5 +38. Also have some 25mm spacers. Might be a better option and everybody won't love them so I'd feel safer. Alway get comments at the lights about the QF's.
Do R32 gtr brakes only fit on a Series 1? What is the difference? If it only hole dia thats not a prob.
Are the shocks the same as R33 in the front. I can then fit my 32 GTR front shocks straight in and then modify the R32 GTR rear shocks to extend to the same length as the R33. Are rear 33 shocks the same length between gtst/gtr?
Are stagea exhaust specific or could I mod a R33 or R32 on easily. I've made full exhausts before so if its just a cut and shut I'll use my 3.5. Fairly quiet.
Is there any particular model to focus on buying to make this conversion easier.
Hoping to swap into the Stag
Forged piston RB26 with -5's with PFC etc. Making just under 300rwkw and only needs inj now for 350+
OS giken triple plate clutch and manual box
A/M diff centre. Very tight
100mm intercooler
Oil cooler
Turbo back 3inch dumps merged into 3.5 exhaust
324mm slotted rotors and GTR calipers with braided lines
Revalved Bilstiens for track work.
For the price of selling the GTR shell and all the bit I don't need plus 2 other cars I own I should be able to do this without it really costing me anything, I get my yard back plus a nice car. All wins
If anybody has any links or info it would be really appriciated or know of anybody with nice cars for sale upto/around 10k.
Cheers in advance.
Should be pretty straightforward. Put a 33GTR box in my S1 and mounts fit and resused auto driveshaft no problem. Probably need GTR ecu and loom. Brakes should fit but will probably need to push guards out for 18 x 10 rims.
i have 18 by 10 with +15 offset of my stagea with them still inside the guards
Auto or Manual stagea?
Auto has 50mm wider rear track (cradle) than a manual
Series 1 or 2, big debat which is better
$10K bugdet will find a nice series 1, or cheap series 2
Series 1 has R33 motor, std auto. not as nice interior, could swap to a series 2 if wanted. 12mm front brake bolts
Series 2 has neo motor, worth more, better looking interior, tiptronic auto, 14mm front brake bolts, different front end look, normally factory side skirts and rear wing, 1-3 years newer.
Couple of cheap series 1's on ebay from $6500
Def would have been using the gtr loom and pfc. Makes life nice and easy.
Gareth, dropping running gear into a cheap Stagea is straight forward. Same issues with dropping into a GTSt regarding pipwork and the added issue of converting to manual. Seems straight forward enough though. No need to cut holes in the firewall, etc. It all bolts over.
wait for mikes arrival re:wheels
Mike is a dirty wheel whore :bunny:
That will either be on a RS4 S or an Autech. I run 18 x 9.5 +22's and in the rear of my auto, they don't fit unless you run about 3 degrees of neg camber.
Darren is on the money with the rear cradles. You can bolt in a cradle from a S14/GTR/etc, with the best bet going for an Aus S14/15 rear end as they don't have Hicas.
To start off with, I didn't really like the S2's however, the front end grew on me and I ended up buying one. For a stocker that you don't intend on buggerising around with or you want to keep it close to stock (ie, boost, turbo, cooler, etc) the S2 is a winner.
Neo motor, tiptronic, if you're lucky to find one like mine, it'll have leather/electric/heated seats, touchscreen navi/climate control etc.
Considering you want to make a monster out of a Volvo Hurse, then I would go for an S1. They are cheaper to buy, parts are cheaper than S2 parts (panels, trims, etc) and you'll be wanting to cut it up anyways.
I found Chris and Min's Stag for around $6800-ish 3 years ago. Something like that now would probably go for around 5k. Leaves 5k to spend on go fast bits if your budget is 10k.
I found mine at auction and got Aaron to import it, etc and complied and on the road it cost me around $13,000. This is what it looked like at auction.
Edited by SABBAi
Interesting regarding the cradle Scott. It would be good to just bolt in what I have becuase it already has a a/m diff centre, cusco adj upper arms, braided lines with slotted rotors and whiteline swaybar. I'm guessing the rear strut towers are higher than in a r32?
I've noticed a few cheap stagea's out here but there aren't to many for sale atm. Might just hang out and wait for a bit. If I can grab one for about 5 that would suit me fine.
Thanks for the help boys!
If you intend to use the r32 cradle you will need to fit offset bushes as the 4 mounting stud/bolts in the car different centres.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
