  • Replies 143
Also look at ku31's kez...
Well I have a new seat in the car... Some nasty old bride thing to get me by... Lol
hopefully will be sporting a velo gp90 with 4pt harness by the nov deca
haha i was so dissapoint when that broke. was looking forward to riding in the beast. shotgun next deca
Yeah that's where it happened, came around the sweeper (on the long wang) and braked too late going into the chicane. Worst part is I still hit the cone! I should've kept the power and on and just blasted through them, would've been cheaper and gotten me a better time :P
Maybe I'll take Dan's advice and get some half dead semis. Chuck them on the Advans and leave the stockies for daily driving.
Yeah that was a massive lock up. I remember seeing the line!
Don't get dead semis unless they are cheap.
hey guyz, i've finally gotten around to uploading my pics. i'm noob so don't expect too much :P
facebook
oh and i noticed that for some reason the same people kept appearing on my camera, so sorry if i didn't get pics of some cars.
Some great pics there! Cheers!
facebook
Nice photo's mate. Love this shot:
facebook
great photos there
i saw at least 4 of my car :)
Had an awesome day. :P
Thanks to all the volunters and event organizers. The battles were good fun in the arvo. But i was understeering alot on the skid pan due to a bent power steering rack haha.
Thanks to all for pics taken. Cant wait to see more and vids.
hey guyz, i've finally gotten around to uploading my pics. i'm noob so don't expect too much :laugh:
facebook
not bad photo's
Can I shotgun a ride during Buller? :laugh:
yes, but once your in your in.... i'm not stopping to let you out half way up! ;)
saw some of mine too :( do u mind if i use them..?? (the ones of me that is)
how did u like the ride roman..??
was yours the sil80 with white te's?
and charles will wrap your front bar for free(every thing comes at a cost)no more cable ties
where will i get my street cred from then? ;)
cheers guyz :) took a heaps more photos but they didn't turn out too well :huh:
saw some of mine too :) do u mind if i use them..?? (the ones of me that is)
go for it, mate. also have the larger, full size files of 3000 x 2500 (or watever the size is) on the comp. pm my sis with your email as i don't log on much. i think she's aphrael or aes_sedai on here.
hey hey just looked 11 picks of my car not too bad having something different at deca
That's cause my dad loves your car :D
cheers guyz :D took a heaps more photos but they didn't turn out too well :ermm:
Booo, Glenn. How can you not know my user name? :P It's actually Aes Sedai guyz. :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
