  • Replies 143
Also look at ku31's kez...
Well I have a new seat in the car... Some nasty old bride thing to get me by... Lol
hopefully will be sporting a velo gp90 with 4pt harness by the nov deca
haha i was so dissapoint when that broke. was looking forward to riding in the beast. shotgun next deca
Yeah that's where it happened, came around the sweeper (on the long wang) and braked too late going into the chicane. Worst part is I still hit the cone! I should've kept the power and on and just blasted through them, would've been cheaper and gotten me a better time :P
Maybe I'll take Dan's advice and get some half dead semis. Chuck them on the Advans and leave the stockies for daily driving.
Yeah that was a massive lock up. I remember seeing the line!
Don't get dead semis unless they are cheap.
hey guyz, i've finally gotten around to uploading my pics. i'm noob so don't expect too much :P
facebook
oh and i noticed that for some reason the same people kept appearing on my camera, so sorry if i didn't get pics of some cars.
Some great pics there! Cheers!
facebook
Nice photo's mate. Love this shot:
facebook
great photos there
i saw at least 4 of my car :)
Had an awesome day. :P
Thanks to all the volunters and event organizers. The battles were good fun in the arvo. But i was understeering alot on the skid pan due to a bent power steering rack haha.
Thanks to all for pics taken. Cant wait to see more and vids.
hey guyz, i've finally gotten around to uploading my pics. i'm noob so don't expect too much :laugh:
facebook
not bad photo's
Can I shotgun a ride during Buller? :laugh:
yes, but once your in your in.... i'm not stopping to let you out half way up! ;)
saw some of mine too :( do u mind if i use them..?? (the ones of me that is)
how did u like the ride roman..??
was yours the sil80 with white te's?
and charles will wrap your front bar for free(every thing comes at a cost)no more cable ties
where will i get my street cred from then? ;)
cheers guyz :) took a heaps more photos but they didn't turn out too well :huh:
saw some of mine too :) do u mind if i use them..?? (the ones of me that is)
go for it, mate. also have the larger, full size files of 3000 x 2500 (or watever the size is) on the comp. pm my sis with your email as i don't log on much. i think she's aphrael or aes_sedai on here.
hey hey just looked 11 picks of my car not too bad having something different at deca
That's cause my dad loves your car :D
cheers guyz :D took a heaps more photos but they didn't turn out too well :ermm:
Booo, Glenn. How can you not know my user name? :P It's actually Aes Sedai guyz. :D
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
