search engine doesnt let you search for "1/4" so everyone put drag times here
spent 2 hours looking another topic
drag 1-4 quartermile 0-400 et
heres mine form yesterday .never dragged aything before
run 1 2 3 4 5
reaction 0.415 0.637 0.281 0.521 0.673
60 ft 2.31 2.29 2.30 2.06 2.16
et 14.56 14.34 14.40 14.10 14.06
mph 96.95 97.10 97.34 96.68 96.89
fat f**kin wagon . itll go better when i get it tuned and a real clutch
https://www.sau.com.au/forums/topic/332999-stagea-drag-times/
Calder park, first time out. M35 Stagea with full tank and street trim. (I only took the baby seats out. :) )
Average reaction time 0.5 seconds
Average 60 foot 2.5 seconds
Best 1/4 time of 13.5 seconds at 171kph due to factory speed cut.
Vids:
I will have to go back now I have disabled the speed cut, hoping to crack into the 12's.
Ok back in feb @ Calder Park
Run
1. R/T:- .692 60Ft:- .000 1/4 Mile:- 16.697 MPH:-85.55 KM/H 137.69
2. R/T:- .620 60Ft:- 2.416 1/4 Mile:- 15.959 MPH:-85.51 KM/H 137.62
3. R/T:- .657 60Ft:- .000 1/4 Mile:- 15.747 MPH:-85.34 KM/H 137.35
4. R/T:- .599 60Ft:- .000 1/4 Mile:- 15.693 MPH:-85.97 KM/H 138.36
5. R/T:- .638 60Ft:- .000 1/4 Mile:- 16.066 MPH:-84.69 KM/H 136.29
6. R/T:- .683 60Ft:- 2.195 1/4 Mile:- 15.580 MPH:-85.93 KM/H 138.30
7. R/T:- .600 60Ft:- .000 1/4 Mile:- 15.531 MPH:-85.55 KM/H 137.69
8. R/T:- .686 60Ft:- 2.168 1/4 Mile:- 15.428 MPH:-87.69 KM/H 141.12
9. R/T:- .712 60Ft:- .000 1/4 Mile:- 15.412 MPH:-87.81 KM/H 141.32
10. R/T:- .658 60Ft:- .000 1/4 Mile:- 15.232 MPH:-88.85 KM/H 142.99
the .000 60 Ft time was because the right markers were not working
pretty happy with this.. once i have some cash on my side i will bemaking mods but untill then.. :)
Fastest was the last run of the night.
and run 5 wass because i forgot to turn the air con off for that run.. :D
Calder park, first time out. M35 Stagea with full tank and street trim. (I only took the baby seats out. :D )
Vids:
Watched your vids, this thing really does get a shift on! Can't wait for higher terminal speed!
Pfft, Commodores, probably thinking "Shit, what kind of V8 does he have in that Volvo, I need more NOS!"
  • 2 months later...
11.33 @ 124mph on street tyres and full weight (1740kg + driver roughly)
Im tempted to test out the new setup (26/30 and 3076r turbo) but clutch doesnt like the power at moment, so until i swap it i wont be seeing any drags, plus i got a bigger turbo (gt35 1.06 twin scroll t4 flange) to go on too if i can be bothered swapping it over.
Well after a hot arvo of 32deg at Willowbank Raceway, I did got 5-6 runs and the clutch started to over heat
Parked it to cool down so I could make the 80-90km trip home.
Run number 3 was the best.
328rwhp
Run1
60ft 2.250
1/4 13.853
mph 101.01
k/mh 162.55
Run 2
60ft 1.960
1/4 13.681
mph 100.76
k/mh 162.15
Run 3
60ft 1.981
1/4 13.545
mph 101.83
k/mh 163.88
Run 4
60ft 2.386
1/4 14.3
mph 99.46
k/mh 160.08
Run 5
60ft 2.158
1/4 13.648
mph 102.66
k/mh 165.21
Edited by darrinspencer
nice work darrin, how does the GT30 go launching the stagea off the line? are you still running on the tune you got back in May/June?
Same tune, hence the 328hp, not the 400rwhp it is capable off.
The launch is had to get right. the weight of the car, with AWD grip puts alot of load on the clutch as I found out.
Not enough revs and it bogs down, too much stinks like hell.
Had to slip it off the line at around 3-3500 rpm.
What kind of clutch do you have ...single plate??
Yeah single organic sprung centre, suppose to be good for 300rwkw. Pretty to drive on the street, esp since I do 80km a day going to work
It is built by Race Clutch (Jim Berry) very well regarded in OZ
Will have to find a streetable twin plate maybe
Have an Rb30 in the planning.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
