what is the point in cleaning the entire plug?
just use sand paper to clean the electrode and centre electrode where the spark exits and meets, no need to clean the rest. then blow dry with air to remove and dust
  • Replies 60
Well he first said that the oxy couldnt caused the earth straps to break, i replied asking what about when they sprayed on carbie cleaner to cool them down along with a bunch of pictures of the spark plugs, pistons and head damage.. he replied that he didnt really see any problems with the damage and that it could mostly be cleaned up with some emery cloth, ill probably try and take the block and head my machine shop tomorrow to get them to inspect the damage, going to be one long sleepless night :S
Yeh he is a reputable workshop and tuner, been impressed with his tunes in the past. Its going to be hard to put the blame solely on his shoulders as i was the one that installed them at his workshop, i was going to just soak them in some petrol for abit as they had fouled up by me after a few cold starts whilst i was having problems with the new ecu, but he said he could just quickly hit them up with the oxy and burn the crap off them. I would of just got new spark plugs but the ones i order always take half a day to a day and the car had been booked in for the dyno that morning.
The reason why the BCPR7ES's went back in was because i was concerned with the brand new BKR5E11's breaking after he suggested that the heat range was no good, :S its a very sad irony =( I should of just grabbed some BCPR6ES's they always have them in stock =/
Id there anything else besides the oxy or the tune that could possibly caused 5 spark plugs to break the way they have???
Jarrod
The guy that sprayed them with the carbie cleaner.. im not even sure if he is employed there, as they were working on a drag car together :S although the tuner was there overwatching.. oh and the spark plugs had cooled down a good 20 mins before they were sprayed.. but they were still a little hot to handle..
Jarrod
yes the fact that after he heated them up to more than twice the usual operating temp, he thought it would be wise to cool them down quickly with carbi cleaner. This keeps getting worse. Heating and cooling them like that would of cause the metal to harden beyond working order. They would have been that brittle im surprised u got them back in the car with out them breaking first. Im honestly concerned that some one in the automotive industry wouldnt know about heat fatigue or thermal shock or hardening of metals.
And if he thinks emry cloth is a suitable answer to scratches in the bore u need to remind him its not a 50 hp atmo engine in a bucket of shit.
u mean to tell me that after 20 minutes the plugs was still to hot to touch???
I dont know how the plug didnt f**king melt if he kept the oxy on it for long enough to get it that hot. I would near bet that the alloy the plug is made from is not exacly in ideal condition after a fight with an oxy
Dont think it makes much difference but i just want to clear up that it wasnt the metal that cracked but the white ceramic insulator nose surrounding the electrode, on the NGK site it does say if the spark plugs get too hot, that the white ceramics do break, i might send them an email on their oponion on the matter. Id say they cracked and as soon as the engine fired up they fell off with the pressure of combustion.
When i first started the engine after putting the plugs back in it was a bit more noiser than usual for the first 20secs, which i found unusual and mentioned to him..
I am a bit pessimistic on a light sand fixing the problem, i'll see what my engine builder has to say tomorrow :S most of the marks are very light.. but there are a few that are pretty deep.
Jarrod
Hi.
I wouldnt be to concerned with the tops of the pistons just put them back in with a new set of rings.That damage is miniscule from the photos. The bore doesnt appear from the photos to have any honing marks unlike the other bore shown. Also there is an area on the left hand side which looks like it wasnt honed correctly. No hone marks are usually an indication of either a tight piston /ring combination maybe gapped incorrectly compared with other bores which have honing. Another indication is the light scoring which may have already been present before your problems. I would remove the valves and check none are bent.
Take the engine to your engine builder or machine shop and have them measure it up and report on it you may get away with a very light hone. The other thing to be checked is your bottom end which may need some attention depending how long it ran after the oil pump stopped pumping.
agreed. 1 is an unfortunate occurrance.
5 is a mistake that needs some responsibility.
re the block...the scoring doesn't look good, but you will need a machine shop to check out whether it just needs a hone or a bore out. either way its not really a problem to reuse up to about 87mm.
1 out of 6 and you could put it down to bad luck, or a manufacturer fauly (if they were new), but because they were 2nd hand already... then you would put it down to posibly one having been dropped. But 5/6! Thats definatly an indicator that something WRONG was done to all of the plugs, and you were just lucky it didnt happen on all 6 cylinders.
Jarrod
And theres your answer right there. It would be interesting to see whats left of the plugs too. Mainly to see if the center electrode insulators just fell apart completely.
This reminds me of something I did as a kid when collecting marbles was all the rage. You could heat up a mable with a cigarette lighter, and then drop it in a glass of water. This would induce thermal shock cracks all through the insideof the mable and give it a fractured/crystal sort of internal appearance(which was cool when your 5 yrs old). This also made them very fragile as it was only the outer skin of the mable that was barely holding the glass marble together....
This is what your mechanic has done to your plugs. Stress cracks all through the ceramics, so they will have fallen apart very quickly the moment they were exposed to vibration and heat. The cracks also are an electrical weakness in the insulator as well, providing a pathway for the plug to break down. Frankly its a miricale that the plugs didnt let go on all 6 cylinders.
I just can't see how a reputable workshop would do something like this. You say that it was someone there that "might not even work there" that cooled the plugs off, why was he even touching them in the first place?
I personally wouldn't name the workshop if I were you, because chances are there is a different story to this. It's just somewhat un-clear as to who actually did this to the plugs, and then how it came about that you were fitting the plugs to the car and not them.
If this was common practice for them, then this would have blown up in there face long before you came along, know what I mean?
Edited by James_03
Ceramic vs ceramic Head and pistons were ceramic coated but the plugs won.
Quickest removal of an engine Jarod and i just figured out why. This is the first time we have ever worked on a car without a beer in our hands.
Edited by Crans
looking back on the facts on how many ppl say its a bad idea to heat them up that way i cant see either why he said that heating them up that way was fine, i still dont like my chances of getting them to pay for any of the damage. Ill explain the story out in full...
Two days before my tune i did all the basic things like check coolant level, bought some more motul 8100, swapped filter, while i was down at auto one i was talking to a friend that i know has a mid 400hp drift skyline and asked what plugs he used and asked him to order me a set. The next day ive gone in to pick them up, payed for them and walked out to the car, in which i noticed they were 5's, i walked back in the store querying the heat range as i know its the same heat range as the standard plug and way too hot for my application and that i usually use 7s. i was told a story that the NGK's work in reverse to bosch plugs and that a 5 was infact a colder plug. Left it at that installed them and drove the car to the tuner in the early hours the next morning.. went over all the basics and as i was leaving i rememberd about the spark plugs that i was a bit concerned about. So i said to him that i was recommended some v notch ngk5's and that i was concerned about the heat range as i usually run 7s. He confirmed my worry and said that they run 8s in there car.. im not a 100% sure on this part but im pretty sure he checked if he had any 7s for me but didnt, i then said that i had some 7s at home that had fouled up on me and that i would just soak them in fuel quickly, clean them up and drop them in.. in which he said to just bring them down and he would wave the oxy over them free of charge ( since i was installing them ) and that it burns the oil right off them and that it brings them up like new and that theyve done it before.. so i agreed and went home to get the plugs and some tools. Got back there walked in and gave him the plugs, he heated them up with a pair of pliers and the oxy, i waited around for 5 mins waiting for the plugs to cool down before i realised that i could go get the car ready fro the plugs to go in. So i pulled out the old plugs and went back inside, in which i askd him if they had cooled down enough yet to handle, he briefly picked one up and was like yeh they are handliable, i started picking them up and by the time i got to the third one i realised that they were still fairly hot. This is when the other guy that im pretty sure doesnt work there as he owns the car they were working on, comes over with a rag and some carbie cleaner and gives them a spray to cool them down, i then went and installed them on the car.
Looking back now it seems retarded and i cant believe i allowed them to do it, at the time i assumed that they had been around drag cars alot longer than me and knew what they were doing, especially when he said he had done it before.
DVS32R- nah i didnt find any ceramic bits in the oil, but it had crossed my mind that it may of caused the oil pump failure
GTRNUR- i couldnt agree more, thats pretty much exactly what happened, as the car made a horrible noise as soon as it was turned on
ill get some more photos, the ones i took were facing the intake side.. the exhaust side is shocking :S
Jarrod
Ive seen people oxy plugs before, usually rotary plugs or platinums, as when they foul they shouldnt be cleaned with emery, and they are expensive. However woth the oxy takes about 10 seconds to do all 6, you just wave a light oxidising flame over them, just enough to burn the oil/fuel.
Unfortunately as he oxy'd them for free, you probably cant sue him.
took the block to the machine shop for now, hes said the pistons are more than likely alrite, will just need a clean up, but 2 of the bores are f*kd and will need sleeving.. is it worth fixing the block or just start again?
He couldnt believe that 5 out of 6 of them broke tho, he had heard of ppl giving them a light going over with a oxy but never to the point where they were glowing red.. and suggested that it may of been deliberately done
Jarrod
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
