Hey guys im new to this site. I was jus wondering how much my r31 gts skyline is worth? Its a 88 model aussie 4door silhoette GTS skyline says its number 64 out of how ever many(ive got told 200)? got all plates under the hood n got the SVD badge on the dash sayn number 64. However it doesnt hav rb30 in it nemore as its got a n/a 25(apparently done by nissan). 5 speed manual with reco'd diff and new pedders racing suspension. Im curious bout the suspension cuz it has the main outside coil then a inner coil then strut jus wondering if its expensive aswell? Im willing to sell as is or im putn my turbo 30 motor and box in it n putn it on road!
Wud be great to hear some ideas n prices on this??? thanks
https://www.sau.com.au/forums/topic/333085-how-much-is-my-gts-skyline-worth/
Yeah i no it aint worth anything with 25 thats why im selln the motor n putn turbo 30 back in unless i can find a gts motor for it. I got it with the 25 n im tryn to get it bak as close to original as possible unless i get the rite offer for it as is!!!!
Why sell the N/A 25 to put a turbo RB30 in? There was no RB30ET nissan's produced either. It would be easiest(and closest to original) to get a cam regrind to GTS specs and an aftermarket exhaust........
Unless you can find the original engine & ECU, your car is worth SFA.
As someone said, why toss a perfectly good Nissan RB25DE to put in an GMH derivative RB30ET. And there is no way your car came fitted with the RB25DE ex factory.
Why don't you just turbo the RB25DE??
Where did you get this vehicle? As I bought an RB30E GTSI engine off a guy in Narrelan, that was doing this same conversion to his GTSI some years ago when I was going to do a monster RB30DET conversion into an MR30 Ti sedatch.
D
Yeah i was thinkn it aint worth nothing thats y i posted on hear n asked! I never said it came factory with a 25 it jus got told it got converted by nissan. Im putn 30 bak in because i got a rb30DET n turbo box for it. Im over turbsin n/a's as i got another aussie 31 i drive n ive been threw 3 motors in the last 6 months due to crackd heads n head gaskets(from not putn thicker gasket on as i know). But yeah if its best for me to keep 25 i cud do so but im jus thinkn i cud wind more boost into the 30DET n use bigger turbo? Im open to suggestions thats y i posted on hear.
you want to go 'slidin' in a gts? seriously go get S13 or a VN or whatever sub-5K smoke machine you wantto terrorisethe streets in.
ning nong.... just get it back to factory spec and sell it in the conditon it deserves.
Its not that hard if you think about it.
Anyone wanna buy it for 4k. Its got adjustable racing suspension n good tread perfect motor n box. Only thing body needs is one drivers side door strip n wing! No dints n only 2 50cent peice rust spots on whole car. Im willing to let it go!!!!!!!!
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
