I've had my R33 for two weeks now and have come across a problem. Over the last 4 or 5 days it has become harder to start. Each time more so than the last. When it does start, it idles smoothly with no other hiccups throughout the rev range. I am the first owner of the car in Oz and I am wondering if the plugs are still for jap fuel (100 octane) and possibly fouled. Could it also be the AAC control valve or the bi-metalic valve?
One other thing I noticed. The car will idle roughly (sounds like three cylinders) but as soon as I touch the accelerator it idles nice and smooth.
Any suggestions?
https://www.sau.com.au/forums/topic/33317-rough-start-up/
hard to know exactly what u mean, when mines cold and i start it i notice its hesitates afew times to bring the revs on cold start idle to about 1200ish rpm if i give the throttle a touch to help it there then its fine, to me its not an issue coz i have checked everything, and its only for 1 second on cold start up then there is no drama. Just check the spark plugs if ur in doubt!!! Its not hard to do champ!! Good luck
https://www.sau.com.au/forums/topic/33317-rough-start-up/#findComment-668200
i agree with SWEETr33 on this one
i have the 32 GTST and it hesitates a little when cold in the morning but other than those like 10secs its fine and then idles perfect.........i have noticed however my car has been of the road for 5 1/2 months now and i started it the other day and was a little worse mainly i think because of the lack of use
im pretty sure just get a set of new sparks and you should be OK
good luck
https://www.sau.com.au/forums/topic/33317-rough-start-up/#findComment-668232
frosty it could be plugs or more than likely just the fuel has gone a little stale from sitting in the lines for those 5 months. Should be an issue when u start it up again. I remember when i went to test drive a r33 that just got off the transport truck, hadnt been started for like 8 months and its ran on 5 cyl's for about the for minute till the stale fuel cleared and it got decent fuel into it
https://www.sau.com.au/forums/topic/33317-rough-start-up/#findComment-668266
Umm, has the battery got some distilled water in it? Harder starts are usually the sign of a battery thats struggling to cope. Especially if its come on all of a sudden.
My 32 is hard to start from cold, but its been like that ever since i got it, still no idea what causes it.
Red17
https://www.sau.com.au/forums/topic/33317-rough-start-up/#findComment-668401
By "rough startup" do you mean it struggles to crank over or just cranks over for a long time? If the latter, it's a very common problem on many 'lines. The way I get around it is if it doesn't kick over within 2 seconds, I let go of the key, wait 1-2 more seconds, then crank it over again, and it will start within 2-3 kicks. If I keep cranking it over and it goes beyond 2 seconds, it will not start for another 4-5 seconds or so.
Recently I have adjusted the cranking ignition injector duty cycle times on my PowerFC which has pretty much fixed this problem. If you're stuck with a stock ECU then you can't fix it this way.
https://www.sau.com.au/forums/topic/33317-rough-start-up/#findComment-669255
The car starts after 1-2 seconds of cranking but feels and sounds like it is running on 3 cylinders. But as soon as I touch the accelerator pedal it revs up to about 1200 rpm then settles into a steady idle. Wierd.
https://www.sau.com.au/forums/topic/33317-rough-start-up/#findComment-670189
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
