Yeah I'm aware of that part Rolls, What I probly should have mentioned is that I'm trying to find the source of why my Rb3025 is so laggy. when it shouldn't be. It's booked in with a shop for diagnosing next week to see if I have missed something obvious when I did the timing.
I guess what I should have said is at idle should the solenoid be seeing any voltage at all? I have 10V @ idle is this normal? and I also have 10V @ 2500 RPM ( with AC on, Car in gear) I would have thought it would be either 0v or 14v depending on which way it defaults to. I also wonder if the 34 needs more load on the motor to trick it to trigger when the car is stationary compared to the R33.
Either way its going to a shop who hopefully will figure out whats causing the issue/s.
it should be seeing voltage at all times as the ECU grounds the solenoid, it doesn't provide power.
Only real way to test if it is getting a signal is to put a current meter on it really, voltage may droop a little when it pulls the voltage but if it is wired to the battery then there won't be any droop as it is only 1amp. If it isn't making a decent click noise then you can rule it out as broken though.
R34 is smart, I think it needs a few things, TPS to indicate throttle, be in gear and also have your speed above 10kph is what I've heard in the past.
Edited by Rolls
Cheers Rolls,
Good point on the earthing. I wired the solenoid directly to the battery and it made a very audible click. So I believe its definitely operating. But whether it's working properly under it normal conditions I'm yet to see. Will keep you informed with what I find. I think you might be on the money with the 10kph bit too.
I set the data logger to record the VTC output and with the car stationary I couldn't get the ecu to trigger. But it appears to trigger an output once moving.
if you really wanna test the solenoid pull it out of the head and make sure it blocks off the oil gallery when earthed out. if it does and its getting triggered by the ecu then its working, the only way for the cam not to advance then is if theres something wrong internally which is very rare
Hey Rob I did that as mentioned in my 1st post
I removed the VCT plug and applied power directly to the solenoid and it clicked as it should have. I measured the voltage at the plug @ idle and it had 10v but I couldn't get it to trigger and go any higher.
which with out rigging the multimeter up and driving around was all that I can tell. But it has got me thinking, Rolls said that the VCT solenoid earths through the ecu. so therefore I wonder if he is possibly wrong on the part that it should always be seeing current. normally with solenoid's or coils there either on or off. supplying current all the time would just create heat especially if its neither on or off.
But all this really doesn't matter because its now at JPC for them to look at and find the problem.
What rolls said was correct and if you put a multimeter across the pins then you should only see either 13volts when the solenoid is energized or 0v when off.
I don't believe the r34's are current controlled drivers but it maybe worth checking to see if the power wire is connected to ignition(as the r33 is) if it is then it should be the same as the r33.
And as for cam phasers not working - I was diagnosing about 1 Subaru a month at my previous job. So I wouldn't rule that out.
The positive pin will always have 12v, the earth pin will only have zero volts when it is on.
So fi you are earthing on the chassis it will always show 12v on the solenoid, so make sure you have both pins in the plug, not just the positive.
Hey guys, yeah when I was testing with the multimeter I never actually earthed to the chassis on either pin. I was measuring voltage between the two pins on the plug.
Therefore from that it would be pretty safe to assume that its earthing constantly. Doesn't matter any way cos the cars in the shop and I can't test it.
Cheers for all your help guys, it was very helpful.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
