Toyota have a dedicated connector repair manual and parts list (massive and daunting to look at, I have it here for geeks):
http://www.chriswilson.tv/repair.pdf
Do Nissan have a parts listing for replacement engine loom connector shells and terminals?
Thanks.
  • 5 months later...
I am in the UK, may I use PM or preferably e-mail instead? There's an interesting thread on one of the UK Skyline forums, here:
http://www.gtr.co.uk/forum/142215-aftermarket-wiring-harnesses-new-post.html
Are you happy to sell small or even single quantities and ship to the UK? Can you supply the terminals, or terminals with tails to suit the connector shells, too? Thanks.
post-72425-0-31700700-1297241532_thumb.jpgpost-72425-0-89215800-1297241561_thumb.jpgpost-72425-0-18977300-1297241619_thumb.jpg
I have just about every plug made for a nissan engine
Hi I actually need a ignition loom connector for a r33 s2. the the coil connector but the other end.
  • 4 months later...
Hey,
I have just about ever fatory nissan connector made new. text me 0431633126
Hi there,
I'm after some connectors to rebuild a CR31 wiring loom.
Is your offer still available? if so require (dizzy 4-way), (TPS 3-way), (CTS 2-way left keyed), (injectors 2-way centred keyed), (idle control 2-way right keyed) connectors.
I think they are called 'timer' connectors.
Any help appreciated
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
