hi guys,
as some of you know ive recently smashed up a valve or 2..
i got my self a cheap new head in great nick... off to be machined, ported and polished and once over while its out...
questions i have tho...
are the cas marking i had on the old head now irrelevant?
if yes, how do i go about finding the new spot to bolt him up to...
and when i put the head back on... line up the 3 points (crank and 2 cam wheels) and drop it on.. and get a belt on ASAP??!!
when putting the exhaust, intake manis, and head back on... do i tighten center out wards, on all 3? and do i tighten bit by bit.. or all center bolts tight as needed,,, and next?
thanx :action-smiley-069:
Edited by chef_stagea
https://www.sau.com.au/forums/topic/333240-timing-reset-help-me-plz/
hi guys,
Your CAS marking will indeed be different. When putting the CAS back on, centre it with the 3 bolts, so you have the same play each way. Then get a timing light and adjust as necessary when its running.
Before putting head back on, set the crank to TDC and turn the cams on the head to their respective timing marks.
Bolt the head up to torque specs from the inside out, in a zig-zag formation. The head gasket packaging should have specs on it. You'll need to go thru this 3 times, getting tighter as you go and torquing to the max spec on the last one.
Same with the manifolds.
Put the cam belt on. Once the head is on, do not rotate any engine components until the belt is on to keep the timing uniform.
Good luck.
as ruby said getting the crank to TDC , and setting the cams to their timing marks is the way to go.
it could be done using the marks u have made, but if u get the belt out by a couple notches the pistons will be meeting valves again and you will be back where u started
ok... thanx guys..
well is it maybe a safer option to get my current head fixed, using parts from the new one?? or is it the same with the cas... center it then adjust as needed?
any one gota legit torque wrench i could borrow for a sunday?? probly not going to be for a few weeks yet..
ive got an r34 manual yes...
it says cyl head bolt
unit (Nm)
1) 29
2)98
3)0
4)25-34
5)95 - 100 degrees (angle tightening)
wtf does this mean :S it says next to it tighten seperatly in several times...
bight, tighten, nothing, loosenish, then swing it 95 degrees :S lol....
cyl head sub bolt? whats this?? 9.0 - 12 NM
Just a wild suggestion here.... you made a rather costly error once doing this. Now you've got to fork out a fair bit of cash to fix the problem, maybe it's best to get a professional to put it back together. You'd hate to be going through this drama all over again
ok... thanx guys..
unit (Nm)
1) 29
2)98
3)0
4)25-34
Adam, as Heslo said, you can't afford to get any of this shit wrong.......unless you know exactly how to define torque sequences (amongst many other things), please leave it to a pro......spend a little now, save a shitload later.
Always my mantra
Another thing, no one will lend out a good quality torque wrench, they are a high calibrated tool, cost an arm and a leg and can easily be stuffed up in the wrong hands.
There are some cheap shit brands around that someone may lend you but I'd never let one of those anywhere near my engine......I'd do a better job going by feel (when my elbow clicks) :rolleyes:
What are you worried about the timing marks for your CAS for as you should use a timing light for the timing. Setting up the timing is easiest thing that you have ahead of you. The timing marks on the cam gear backing plate are factory markings and it won't matter what head you have on there they will match up with the cam gears.
As a double check you can count the teeth between the marks.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
