lol, my club is EBAY car parts
also, bugger harry, sam collins just went 58.13 today http://www.natsoft.com.au/cgi-bin/results....21/10/2010.LAKE
new road reg'd sil record!
raiseth the bar :] time for more power dammit $$$ 200kw gentlemans agreement? lol
  • Replies 204
wow, quick time at the lake. I'm guessing it hasn't been under water with all the rain that has been about.
So who has entered for the Nats, BBQ at my house on the Friday night.... or the Palace Hotel, excellent food.
Had a second look, seems some of his times are genuine maybe :) So many very inconsistent times though.
lol, their timing is a joke. doubt you could rely on any of it. I briefly looked at the top 10 cars and all of them had bullshit laps. laps went from 1min mark and then one magic 49 sec lap etc. laughable.
sam with a 58.1 looked to be about the first 'legitimate' time on the leader sheet and he was in about 11th place!
they really need to do something about it. there's no point going there if the times are so unreliable. and we're paying top dollar for the Lakeside events... They should install the same radio frequency timing system they have for sprints at QR. Or hire out Dorians like other tracks do.
Sam posted some video on another forum - http://www.youtube.com/user/scs15
Good, I'll book a table for two!
See if you can get a bigger table! If not - we are staying at the Centrepoint Midcity Motel, maybe catch up for a couple of beers?
Still got gearbox issues with 33, cannot keep OS 3rd in for one event.
Anyone got a 34 box in Sydney or about there somewhere?
Worst comes to worst, will take the 32, will enjoy knocking some cob webs out of the old dear anyway!!
Hopefully have some news on classes this week!
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
