I'm looking into doin a RB26 build, and am looking at some garrett GT turbos, has anyone done any twin GT conversions, I am looking at something comparable to the TD06/20g twins.
I've been told the GT35 with a 0.63 housing will spool up quicker than a GT30 with the same exhaust side, due to being a newer design, does this sound right???? I would have thought the GT30 would still spin up quicker.
Any help would be much appreciated thanks.
https://www.sau.com.au/forums/topic/33329-garrett-gt-questions/
fyi,
both the GT30 & the GT35 are of the 'new GT design' and share the same compressor wheel, where the GT35 has a larger turbine wheel.
given this, the GT30 would spool quicker the the GT35 if the same size turbine housing was used.
btw, how much power are u after?
the reason i ask is that two GT35's (rated at~600hp each with .63 housing) on a RB26 would be pretty laggy for normal street use, but then again, it all depends on what u want & need.
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
