Hi Riceline, in your picture you cut off the 4th connection, the one that goes to the PCV valve on the plenum.  It is on the cam cover juts down from the blue one in your picture.
If you open up the angle of the photo a bit so we can see the inlet plenum, then I can draw on your picture the choices you have for plumbing up a catch can.  Yes that's right you have CHOICES, there is not a wrong and a right. :P
Id be extremely interested in seeing this too, I assume itd be along the same lines for a GTR? Looking at putting one on, what would be the best way of doing it?
  • Replies 64
Exactly the same for a RB26DETT, or an RB20DET or an RB25DET or an RB31DET (in my case). But keep in mind there is no "best way", you choose whichever suites your requirements.
I call the choices :cheers: ;
1. 100% plumb back
2. 50% plumb back
3. Zero% plumb back
Anyway, more when the picture is up. :wave:
So what options do/dont u have if your catch can isnt vented?
I have a trust can which is basically hollow but looks cool.. not vented.. u know the one.
Whats the best option for say; 230rwkw or less, running either standard or hiflowed turbo, big intercooler, on 12psi constantly?
I think this suits alot of people...
Is this right?
Let's try this one, it's the open to atmosphere catch can;
The idea is to only have one connection from the cam covers as they are joined by the standard pipe. The PCV valve and the connection to the inlet before the turbo are blocked off. You can have a return (drain) to the sump form the catch can if you like. Don't T it into the turbo oil return as it is under a bit of pressure and the oil can run up into the catch can.
The other 2 options follow in separate posts. :D
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :D is blow-by the same as air from a bov that is being vented to the atmoshere?
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :) is blow-by the same as air from a bov that is being vented to the atmoshere?
Good question R31 POWER, but if your engine has enough blow by to cause idling problems, then it is not the blow by that you should be worried about. :spew:
Sorry for the delay, virus on the laptop :type:
This one I call the 50% plumb back, because half of the time (no boost times) the air from the catch can is being sucked into the inlet manifold via the PCV valve;
It is not my favourite, because you can still get a bit of oily air into the engine, but since it doesn't go in under boost (the PCV valve is closed then) detonation isn't much of an issue. At least you don't get any oil into the intercooler and its pipework.
The last is 100% plumb back, all of the air goes back into the engine. Some goes via the PCV valve, at times of no boost. When there is boost, it goes back via the inlet system, through the turbo, the intercooler and its pipework. :uh-huh:
The idea is the stainless steel wool, helped by the lower velocity in the catch can, catches the oil and removes it from the air before it goes back into the engine. This is the environmentalists favourite :alien: and is the easiest to get engineered.
SK,
How would you plumb it, if emissions were not an issue, as in a 100% race engine. Metohd 1, 2 or 3 ?
On the race cars we run open to atmosphere. We do run 2 pipes to the catch can and remove the joiner (standard) pipe between the cam covers. It's not really necessary on a road or combo car though, the one pipe does the job OK.
Hope that helps :)
So, would it be acceptable to plumb the PCV line to the catch tank, and leave the joiner as is, with the tank vented to atmosphere ?
As long as you block off the unused plumbing and fittings. I gotta ask why though? :confused:
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
