Hi Riceline, in your picture you cut off the 4th connection, the one that goes to the PCV valve on the plenum.  It is on the cam cover juts down from the blue one in your picture.
If you open up the angle of the photo a bit so we can see the inlet plenum, then I can draw on your picture the choices you have for plumbing up a catch can.  Yes that's right you have CHOICES, there is not a wrong and a right. :P
Id be extremely interested in seeing this too, I assume itd be along the same lines for a GTR? Looking at putting one on, what would be the best way of doing it?
  • Replies 64
Exactly the same for a RB26DETT, or an RB20DET or an RB25DET or an RB31DET (in my case). But keep in mind there is no "best way", you choose whichever suites your requirements.
I call the choices :cheers: ;
1. 100% plumb back
2. 50% plumb back
3. Zero% plumb back
Anyway, more when the picture is up. :wave:
So what options do/dont u have if your catch can isnt vented?
I have a trust can which is basically hollow but looks cool.. not vented.. u know the one.
Whats the best option for say; 230rwkw or less, running either standard or hiflowed turbo, big intercooler, on 12psi constantly?
I think this suits alot of people...
Is this right?
Let's try this one, it's the open to atmosphere catch can;
The idea is to only have one connection from the cam covers as they are joined by the standard pipe. The PCV valve and the connection to the inlet before the turbo are blocked off. You can have a return (drain) to the sump form the catch can if you like. Don't T it into the turbo oil return as it is under a bit of pressure and the oil can run up into the catch can.
The other 2 options follow in separate posts. :D
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :D is blow-by the same as air from a bov that is being vented to the atmoshere?
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :) is blow-by the same as air from a bov that is being vented to the atmoshere?
Good question R31 POWER, but if your engine has enough blow by to cause idling problems, then it is not the blow by that you should be worried about. :spew:
Sorry for the delay, virus on the laptop :type:
This one I call the 50% plumb back, because half of the time (no boost times) the air from the catch can is being sucked into the inlet manifold via the PCV valve;
It is not my favourite, because you can still get a bit of oily air into the engine, but since it doesn't go in under boost (the PCV valve is closed then) detonation isn't much of an issue. At least you don't get any oil into the intercooler and its pipework.
The last is 100% plumb back, all of the air goes back into the engine. Some goes via the PCV valve, at times of no boost. When there is boost, it goes back via the inlet system, through the turbo, the intercooler and its pipework. :uh-huh:
The idea is the stainless steel wool, helped by the lower velocity in the catch can, catches the oil and removes it from the air before it goes back into the engine. This is the environmentalists favourite :alien: and is the easiest to get engineered.
SK,
How would you plumb it, if emissions were not an issue, as in a 100% race engine. Metohd 1, 2 or 3 ?
On the race cars we run open to atmosphere. We do run 2 pipes to the catch can and remove the joiner (standard) pipe between the cam covers. It's not really necessary on a road or combo car though, the one pipe does the job OK.
Hope that helps :)
So, would it be acceptable to plumb the PCV line to the catch tank, and leave the joiner as is, with the tank vented to atmosphere ?
As long as you block off the unused plumbing and fittings. I gotta ask why though? :confused:
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
