  knore said:
Most catch cans only have 1 inlet 1 outlet, so for the ones where u need to attach 3+ hoses to it, do u just use a T piece etc?
The ones we use have 4 fittings, 2 inlet, 1 drain (outlet) and 1 filter. There is no reason why you couldn't use a T piece although a Y piece would be better for plumbing. :)
  • Replies 64
  knore said:
Even with the pictures im still clouded as to which way i should use mine
I found this photo, what does this setup offer?
This looks llike the 100% plumb back alternative. It is a little hard to see the PCV pipework, but I suspect that both the inlet and oulet for PCV is plumbed to the can. Certainly the inlet to the turbo is plumbed back, so it would makes sense if the PCV was similarly plumbed back.
Why are you still clouded? :(
For what it's worth here's my setup....figure out which one it is . Remember most bought catchcans have 1 inlet and 1 outlet the inlet should feed to the bottom of the can
http://www.skylinesaustralia.com/members/5...sCar/engine.jpg
  Sydneykid said:
As long as you block off the unused plumbing and fittings.  I gotta ask why though? :confused:
Well, we're recomending to block the PCV line on a vent to atmosphere setup, so if you block the plenum side of the PCV line, and use the PCV port on the side of the rocker cover, you get a very tidy catchcan setup with only one hose :(
This is the style of catch can we use. http://www.gcg.com.au/catalogue/Oil%20Filt...tor%20round.jpg
It has the 4 fittings;
*2 inlets on the side at the top (we run a piece of pipe to the bottom and then cover them with stainless steel wool, inserted via the large air filter fitting.)
*1 drain (outlet) at the bottom (we put a tap on this, so we can open it and drain it)
*1 filter on the top
This setup is the same as mine, it still vents to the plenum via the PCV valve when neg pressure is present in the plenum and vents via the catchcan to the turbo intake pipe when pos pressure is in the plenum....only diff is my catchcan is on the oposite side to shorten the tubing and looks tidier. There is no venting to atmosphere....it's on my street car....and legal :D
Yeh sweet that sounds perfect
Only thing is i want to block the PCV valve, seems to have all benefits and no disadvantages from doing so
So whats the best way to block the two holes/hoses? Im assuming just cut the hose going from the plenum to the rocker cover, and screw a bolt into the hose holes
i went to power diggers workshop in ingleburn today and the owner told me that the boost pressure source could be teed from the vaccum hose that runs from the throttle body to the air con canister.I didnt question it because ive had one on the car in that exact same location ever since i bought it, it had just been capped which means it can be located even closer again.:cheers::(:mad::mad:
A question about my proposed setup for an oil catch can.
1.In this picture you can see the pipe that goes from the plenum to the rocker cover.Now if i put a aftermarket pcv valve in the middle of this hose so pressure only travels to the rocker cover and not backwards to the plenum is this allright to do?
The catch can is rigged up the same as the one in the picture.
What i was thinking was that by putting the valve in there it would only flow air when on boost and when off would eliminate oil travel to the plenum when off boost.And the catch can setup should pretty much take care of the rest of the oil blowby on its way to the intake pipe.
tell me if i am wrong please.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
