I would go for a digital dash like a Race Technology one and run it off the ECU sensors
Is this the dash you are talking about? I'm using a Vipec, can it plug in directly to that?
  • Replies 467
also install my nismo brake master stopper yesterday and dam it makes a huge different to my pedal makes me think my brake masters might need replacing. pedal is very firm now and as soon as i touch the pedal the brakes work unlike before were there was no initial bite
few updates bought some more parts....
ARC Radiator (had no plans to upgrade but this was so ridiculously cheap couldn't past it up)
Std GTR lip
Blitz EBC SBC-3
Nismo rear bushes for shock mounts
ohh and my hks front pipe arrived today 2x70mm -> 80mm; fits the tomei dumps very nicely
The factory tank does a very good job, is mounted well for weight distribution, and has enough capacity for quite a few laps, even on E85....... Hi Octane 32 GTR still runs the factory tank.
Hi Ben,
Do you know what spring rates the R32 runs ?? There's been some discussion on here re spring rates, I'm pretty sure Mark used to run fairly stiff rear springs to stop the front wheels from lifting ?? Probably diff. setup now with Russ driving though.... :-)
cheers,
JB
Well, it had 450/350 (Yes, softer than I run in my Targa 32 GTS!) in it until last weekend when we doubled the rates and had Murray stiffen the shocks to match...... it was terrible around Lakeside, but it also lacked any form of undertray and was porpoising in the front. First time the car's ever understeered. (Same Whiteline bars on soft set, messed about during the day but made no real advances)
With the old springs in it, as you may know it would actually lift the inside front exiting corners, but was a dream handler..... very forgiving and lots of traction. Still seems to be the preffered setup, but time and some sorting may change that.
Edited by Marlin
Would just like to confirm some details regarding tyres and rims.
The best size for track rims would be 17x9.5 +15 ish? correct
and for semi-slick best size selection im like 255/40/17? (do i have to run same size front and back?)
A 255/40/17 will foul the rear guards in an RE55 tyre on a +22 offset. Mine did anyway. So it will get ugly in a +15.
The front is a bit different. With the amount of neg camber you need to run you will probably get away with a wider offset than a +22.
Bridgestone recommend a 9" rim for a 255 bag tyre - you don't have to use drift tyre/rim sizing combinations....
Check also that a 17" rim will clear your brake rotor/calliper. 17" usually means 3345 rotor at maximum unless you are carefull with calliper & rim selection.
Wow, doubling is a big call! it also blows out the difference in front/rear by another 100lbs hence the understeer I'd reckon..
450/350 is softer than I recalled - thanks Benny.
Slightly off topic, but, Marlin... do you know if either of the HiOctaneRacing GTR's use Tomei intake and exhaust valves (+1.0mm) as well as most of Tomei catalogue?
Thanks
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
