  • Replies 467
I think the trust pipes works. along with what ever nismo ones i have seen on the 32..
the hks however is fail for arc box.. so either sell the airbox, or sell the hks kit and grab the trust job..or go custom!!
I think they're fine, I wouldn't buy a new one though due to the silly cost
agree, i think they are around $500-$600 brand new maybe more. mine came with the car hence why i want to keep it and i just bought new ARC filter for mine which cost me somewhere are $200 :)
I agree, super smooth ports and inlet piping are shite for airflow. As the inlet air sticks to the piping / port walls and slows down.
Edit - think of a golf ball vs a pingpong ball, which one goes faster through the air.
im pretty sure from what i remember in fluids class. you want a smooth port in internal flow like a pipe (inlet ports) so the flow
doesn't get affected by the boundary layer or turbulence due to sharp edges.
external flow you want a high Reynolds number thats why there's ridges on the golf ball
mate, your example doesnt work, you are comparing fluid flow to a particle in fluid. you cant compare apples with oranges.
Then why has there been 30 odd years of PRACTICAL testing on Aspirated V8s / f1 cars / turbo cars etc, hence CNC ported aftermarket heads leave the cut marks in the ports, also people have chrome plated the ports on engines and gone backwards Hp and torque wise.
Practical real world testing on these things has proven that theory isnt always correct.
fair call for the surface finish of the head, but that comes into air/fuel interaction.
for the intercooler piping, i thought the idea is to get the air to the head as quick as you can.
back on topic,
whens the planned first outing for this thing?
well looks like nismo hard piping is out of the question too...
starting bidding on the auction for nismo hard piping and hks i/c piping...
i stop bidding at 160,000yen lol :) and i still got out bid
Brand new the kit is 155,000yen without tax lol, and already bought myself a hks i/c piping kit so anything more isn't worth it
edit: WOOO! auction ended at 192,000yen that is over 2k!
Interesteding makes me think the nismo hard piping kit is made for r32 and not just a r33/34 kit.
seeing as you can buy the nismo kit for 155,000 and hks kit is 35,000yen = 190,000yen brand new for both why would someone pay 192,000yen for a second hand kit lol
Edited by Kaido_RR
back on topic,
december if everything goes well. but looks like i have a problem with the hard piping kit so will need to sort that out before the car is ready to go.
Also need to wait for my track rims and tyres to come :S so finger cross they should be here by dec
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
