GTS-t and GTR are not the same.
You have extra weight, totally different characteristics with regards to over/understeer and so on.
You are basically discounting advice from people who've been doing this stuff for many years... and running some very respectable times.
And no point "trying" different spring rates initially as you'll spend more time learning about the car, how to drive it fast and so on.
I'd only be toying with suspension in detail after at LEAST one full year of track days.
  • Replies 467
I would suggest reading this with regard to tuning D-Jetro vs L-Jetro on individual throttle engines
http://www.motoiq.com/magazine_articles/ar...e-1-part-2.aspx
This is true... was thinking it would be a killer to setup.
Hotwire AFM's are not a restriction like the crappy old flappy ones used to be, so other than maybe simpler intake packaging I don't see the appeal with going MAP.
AFM's will also respond to flow changes in intake and exhaust - always good to be tuning after any change but in general I think AFM's are a much more flexible solution.
im not discounting anyone advice, hence why im starting with 6/8 combo. i personally was just going to go with 10/10 and be happy with that. but after starting this topic and reading people input i through i start lower and see how that goes, i don't plan to change anytime soon but once the car is at the level i want it and i have constant lap times i will see what affect a higher spring rate does to my lap time.
As i have yet to find any information regarding running spring rate A v's spring rate B
That is because there is no direct answer for that question... best way to figure it out is listen to experienced people and work out a ball part to start from. Then the development can begin from there.
I would also disregard most things they do in Japan as far as race car suspension is concerned.
Sorry if you have already covered this - but what sort of tyres are you going to be running?
Full slicks or semi's ?
Atm im just running street tyres re001r but have order another set on rims which will run re55s so just semi. I will be starting off in time events so full slick will be out as i wont be able to get enought heat into the tyres
Thats the plan, its a shame the owner doesnt know the spring rate of the coilover :D and being in japan there is no way of me finding out till i get them.
The plan is to go swift 6/8 and then try to work out what is the go with the assist springs on the front, im assuming something small like 2 or 3 would be best suited ???
I am about to modify and fit up a set of sach shocks to my little gtir pulsar which I'm stuffing around with for shits and giggles.
When it's ready to go testing why don't you come out to the circuit with us and get a first hand experiance of what it takes and the methods we use to make a car do what we want it to do. Minus the guess work.
No fancy arms or massive chassis changes just a fairly well thought out chassis with quality parts that I know will deliver the goods. I think you'd be very suprised how easy it is to turn a car all pear shaped with the wrong choice of parts or heading off on an expensive tangent when the solution is very simple.
I can already forsee you forever going around and around in circles chasing fast cars with alot less coin thrown at them because of fundamental mistakes and choices your making now.
I don't know everything and you could prove me wrong, but the offer is there for you to learn a thing or two which others may not already know.
i would take you up in a second, but i have a feeling your not in perth :whistling:
In your honest opinion were do you think im going wrong? Atm the plan is not to change any suspension arms, just new set of coilovers (as the current spring and shock combo is Shockley hard, front adjustment doesn't work and rather large knocking sounds from the rear struts)
I will be going with Quantum T5-RS coilovers with unknown swift springs plus assist springs on the rear (again unknown rate)
so first think i will do once they arrive is remove the springs and replace them with something i know the values of, i will be using swift springs but as i mention im not 100% sure on the rate i will use was looking at the 6/8 region?
Do gtr required a higher or lower front spring?
What i do later on is up to how well the car goes. i want to run constant before i start changing this that and everything else, as i have no gtr experience, all my driving at the track in the pst 4years was a gts-t which was pretty simple to drive. For sure i want to run I.k gear etc but i have a feeling i will be making things alot harder for myself if i take huge jumps in the beginning.
aiming to have around 350-400hp with the BCNR33 N1 turbos if that matters
edit: i know from page to page things seem to change but at this stage im set on just going with a basic setup and running constant times before i start changing everything
Edited by Kaido_RR
Just got my order put in for the Swift springs for the Ohlins. Im using 6/8. There the part numbers if you need them. Price is per Pair to.
Swift Spring Z65-178-080 - 14,460yen.
Swift Spring Z65-254-060 - 15,930yen
thanks, are you running and helper or assist springs with the Ohlins?
I through i would start a new topic as i made the jump and bought a gtr :(
My focus for this build is suspension and aerodynamics and im looking for input from other GTR owners.
Here is what im start with
1990 BNR32 GTR 107,000km
Engine Swap which has done 50,000km (believe it is a r33 gtr engine)
R33 N1 Turbos
Bosch 044 Fuel Pump
ARC Airbox
HKS Hipower Cat-back exhaust + decat pipe
bleed value
No aircon
Hicas has been remove
Advan 17x9.5 +19 with 235/45/17 RE001 rubber
Bee-r suspension (looks to be just bee-r shocks with std spring however the car is pretty stiff but ride high looks std)
Parts which i will be using from my previous track car
AP Racing CP5500 Front Calipers (4pot)
Endless slotted 323 disc (32mm thick)
Endless cc-rg pads (front and rear)
APP Braided brake lines
Bride Zeta 3 seat
Nismo Steering Wheel
Nismo 4point harness
Now i have a HKS Oil coller (Type R remount oil mount + built in thermostate) the kit is for an R33 and the lines were just long enough for me to mount it on my driver side vent on the r33 and i think this MAY be an issue if i use it on the r32 as the bov are there, Should i just sell the kit and buy something made for the gtr or try and get it to fit?
Now the plan was to completely strip the interior and put a cage etc however my dad has decided he likes it so he wants to drive it on the street :happy: so that plan has gone out the window until i can convince him to buy a R34 gtr or R35 ahaha.
Please note i am a brand whore ahaha!
Now Suspension Setup Time.
After doing alot of reaching and research i have come to two choice regarding suspension arms setup
1.Ikea formula
2.Nismo
Now i would prefer to go the Ikea formula as i ran some of there gear in my r33 and just look the quality of the parts and the adjustment levels. However after reading "Merli's R32 Track Bitch" topic looks like he had issue with the Front LCA and full lock due to them not having any bump stoppers. Do you think this is enough of an issue to warrant me using nismo items (note the car will be street driven by my dad :) )
For swaybar it seems that everyone loves the cusco gear, so i will go with them if i can't get any ARC ones are a reasonable price.
LSD i will be looking a NISMO gear; 1.5way rear and 1way, nismo have a new lsd out which uses carbon plates which i will look into and see if it is worth the extra cash.
Now coilovers is were things get interesting. i ran Tein RA in my r33 and love them i would love to find some for my r32 but so far no luck. So the other opinions i have are ohlins, Kw (heard good things about them), possible HKS to start off with (something like Hypermax 3 sport however i know they are more an entry level street/track setup then a full hardcore race setup) or maybe nismo.
I have found some nismo s-tune suspension however i am not too sure if they will be too soft and i don't think nismo made there hardcore suspension for the r32.
Spring rate i am set on starting off with something around the 8/10 or 10/10 mark, alot of people will say thats too hard/stiff but i ran 10/10 in my gts-t and it was perfect and from what i have look at that the jap run it seems to be the normal.
Have a miss anything regarding suspension that i should look into?
Now onto Aero bits, to start off with i think i will just go with a front diffuser/undertray and rear diffuser.
rear diffuser i may use the one i bought for my r33 but never fitted
Front i am looking at getting this one
Im not sure if its aero properties are that great but its a starting point.
Front bumper im looking to replace with a n1 item so i can have the vents and just run the std lip.
Engine Wise, im looking to keep everything pretty much stock. Just an ecu upgrade and a tune with some more boost (car feels quick enough for the time being)
Thats about it for now, if i think of anything else i add it later :(
If anyone has any input please feel free to add, i have zero gtr experience and i have learn with my gts-t that it is better to do things right the first time.
Cheers Michael
Hi,
probably no news but aero tweeks are useless. The GTR would need a whole new nose-section to lower cf value. I found front bumper canards very useful - I made some for a TT R DTM here in Germany - look much more agressive than the good old canards for GTR's and work great.
One useful idea is redirecting the air through the IC opening back out through the hood. Gives downforce and great handling on corners. Little space though and more for cars with relocated radiators to the trunk. Will have a look for pictures and upload something.
TAke care
What do you mean by 6/8? Are you really running softer springs in the front then the rear?
some numbnuts did this to my car... Chris just pulled the Teins out to get rebuilt and the springs were 10F 11R... no wonder the rear just wouldn't settle over rough surfaces... going with a softer rate front and rear now so should put the power down better... must have been a mistake when the original owner ordered them, can't see anyone in their right mind doing that on purpose!
Can I ask who you ordered through Luke?
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
