I would go for a digital dash like a Race Technology one and run it off the ECU sensors
Is this the dash you are talking about? I'm using a Vipec, can it plug in directly to that?
  • Replies 467
also install my nismo brake master stopper yesterday and dam it makes a huge different to my pedal makes me think my brake masters might need replacing. pedal is very firm now and as soon as i touch the pedal the brakes work unlike before were there was no initial bite
few updates bought some more parts....
ARC Radiator (had no plans to upgrade but this was so ridiculously cheap couldn't past it up)
Std GTR lip
Blitz EBC SBC-3
Nismo rear bushes for shock mounts
ohh and my hks front pipe arrived today 2x70mm -> 80mm; fits the tomei dumps very nicely
The factory tank does a very good job, is mounted well for weight distribution, and has enough capacity for quite a few laps, even on E85....... Hi Octane 32 GTR still runs the factory tank.
Hi Ben,
Do you know what spring rates the R32 runs ?? There's been some discussion on here re spring rates, I'm pretty sure Mark used to run fairly stiff rear springs to stop the front wheels from lifting ?? Probably diff. setup now with Russ driving though.... :-)
cheers,
JB
Well, it had 450/350 (Yes, softer than I run in my Targa 32 GTS!) in it until last weekend when we doubled the rates and had Murray stiffen the shocks to match...... it was terrible around Lakeside, but it also lacked any form of undertray and was porpoising in the front. First time the car's ever understeered. (Same Whiteline bars on soft set, messed about during the day but made no real advances)
With the old springs in it, as you may know it would actually lift the inside front exiting corners, but was a dream handler..... very forgiving and lots of traction. Still seems to be the preffered setup, but time and some sorting may change that.
Edited by Marlin
Would just like to confirm some details regarding tyres and rims.
The best size for track rims would be 17x9.5 +15 ish? correct
and for semi-slick best size selection im like 255/40/17? (do i have to run same size front and back?)
A 255/40/17 will foul the rear guards in an RE55 tyre on a +22 offset. Mine did anyway. So it will get ugly in a +15.
The front is a bit different. With the amount of neg camber you need to run you will probably get away with a wider offset than a +22.
Bridgestone recommend a 9" rim for a 255 bag tyre - you don't have to use drift tyre/rim sizing combinations....
Check also that a 17" rim will clear your brake rotor/calliper. 17" usually means 3345 rotor at maximum unless you are carefull with calliper & rim selection.
Wow, doubling is a big call! it also blows out the difference in front/rear by another 100lbs hence the understeer I'd reckon..
450/350 is softer than I recalled - thanks Benny.
Slightly off topic, but, Marlin... do you know if either of the HiOctaneRacing GTR's use Tomei intake and exhaust valves (+1.0mm) as well as most of Tomei catalogue?
Thanks
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
