turbos are r33 n1 so steel wheel.
I highly recomend ditching them in favor of some garret -5's. R33 N1's are laaaaagy, they will handle a tonne of boost...but you need a tonne of boost. Dad ran 25psi all Targa this year, and the turbo's are still like new.
My GT2530's (-5's) are 1000rpm more responsive for the same power.
  • Replies 467
yeah i notice they are very laggy, :S
was recommended -5 by my tuner, he advise if i keep the n1 i would need to rev them and open up the rev's more. and i will most likly get lag during gear change unless i turn up the rev past the stock limiter.
will see how they go on 18-20psi of boost, but its looking like the hks gt-ss or -5 will be the go at the end of the year.
out of interests what do -5 go for brand new?
what power did it make at 25psi?
Edited by Kaido_RR
Can attest to this, I have R33 N1's and make 431rwhp but the power is super laggy like your really not getting a good shove until 4500+, getting -5 early next year or this year money depending.
On built 32 GT-R.
Ok turbo choice are limited to two
HKS GT-SS or HKS GT2530
or garrett similar.
I would like to keep lag to min but still retain some top end, would i be able to achieve this with the gt-ss or will i need to go the 2530 power goal is 400-500hp but that isn't the important part i manily want good respones
or garrett similar.
Go have a read through the -5, -7, -9 thread, its approximately 40 pages long, however, fundamentally everything relating to the turbos your looking at and would want to know is in there, pretty insightful.
Personally I would choose the HKS 2530's although these are the most expensive option, I think should you choose the GT-SS's you will be very happy with the response (which is excellent as I've experienced first hand) you will want more power, especially as this is track oriented, consider that you will NOT make much more (relatively) then 300-330AWKW on PULP with GT-SS's Whilst 2530's should net you between 350 - 450 AWKW.
Edited by Nee-san
Thanks :P
im leaning towards the gt-ss however i know the main track here in perth does like top-end however im trying to weight up how much track time will be done at the track and how much track time will be done a timed auto-cross/tarmac rally events. As i have a feeling the gt-ss will help more in the tight events
Thanks :P
I think the best thing for you to do mate is sit down and be honest with yourself about what exactly you are going to do with the car, break it down percentage wise if that makes it easier to think about, It really does make decisions about the direction you take your development alot simpler.
I did this when I was struggling with which way I wanted to go with my car.
For Autocross you couldn't possibly look past the GT-SS's
For Tarmac rally, and hill climbs again GT-SS's look very hard to pass on, however there is an argument for the bigger turbos depends whether you can actually use the power your making, remember its actually quite easy to add power to a race car and a hell of alot harder to make it faster in other ways once you have covered the basics.
In the end as I have said, It's about what you want from the car and what you want to do with it, the best thing about getting opinions, mine included is that you can take them and leave them.
another update,
just bought my set of track rims, however not sure if i went over board with the sizing
17x9.5 +12 plan is to run RE55s or AD048 in 255/40/17
Good thing is Nismo/rays state that sizing will clear big brakes (had issue with my old nismo rims not clearing my AP). Be interesteing to see if i run into issue once the car is lowed and alignment setup is done with the rim hitting the guards
another update,
What did you pay for those bad boys, PM if you don't feel comfortable saying in here ?
Highly unlikely on a BNR32. I run those exact sizes on my S14 track car with stock guards and they fit fine.
Also, what Nismo wheel were you running that they did not clear a 330mm 4pot AP? I am looking for a second set of 17s to clear 343mm and 4 pots
Nismo LMGT2 but i think it was more an issue of width and offset, running 9inch front with +35 won't clear the AP i needed to run a +15mm spacer.
My mate with the evo was keen to buy my rims so we test fitted them on his car even with the +15mm spacer won't clear the evo 7 brembos at the front
another update,
9.5's arent going to be anywhere near too wide.
Even 10s fit easy to a 32 with no guard work required.
I put 19x9.5+11's on a 32 recently and they fit pretty well at the back with stock camber and slight tire stretch.
For the track running a square tire you will probably either need camber arms or a slight pull to fit them all round or else run 4wd ride height.
Personally I would choose the HKS 2530's although these are the most expensive option.
Did you see the irony in your comment there?
He's gotta pick them by default then :D
Either way it's Garrett -9 (GT-SS) or the -5s (2530).
Buy the Garretts, for all intents and purposes they are same - HKS's are not worth the coin new.
-9s for tighter stuff = winner.
-5's for a track there top speed/top end is more important.
But if you are going to be doing more rally/khana type stuff then you want the response and transient gains the small turbo offers for quick on/off type stuff and much more progressive.
My GT-SS's will be for sale shortly (1month or so once i ge the motor out, motor buyer doesnt want em)... :(
Lol nismoid,
But everything /\ he's said is right, buy the GT-SS's off him or if you need the power go 2530's if you have the cash.
or garrett similar.
As the car is in Perth there are some things to go by.
If it is to be run at Wanneroo there really isn't much downside in the larger turbo.
If it is run in kharnas/AHG etc then get the smallest turbo that will make the power you are chasing.
Is the 400-500hp at the wheels or not?
17 x 10 +15 fit on GTR's with ease.
A +22 rim on an R32 with a 255/40/17 RE55 will foul the guard. Mine did. So you will need work to clear +11's.
It is a track setup. Hence needs whatever camber/ride height makes the car go hard, not whatever is needed to make the tyre fit. Plus remember you will be (or should be) smashing the thing over kerbs to make lap time - which doesn't go well with all this flush fitment bullsht going about.
Yeah that was my worry . was a rather last second decisions to buy the rims and i was 99% sure i won't win them at the price i bid, however i did! So will most likly swap my street tyres onto the nismo rims and use my advan for track stuff (they are 9.5j +19) and see how that goes.
What guard was fouling the front or rear? (or both)
Risking not sure if that was directed at me or not but my last track car was far from a posser race car lol so i think the gtr will be fine.
Thanks Djr about the turbo info. i am thinking if my goal is speed event series then the gt-ss or garrett similar will be the go, whatever i can find cheapest at the time.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
