after having a talk with my tuner i think i go -5 turbos what cams would suit them? is 280 to big
The ones Nissan put in it when they built it will be fine. Just get some cam gears. There are 4,268 threads on this very subject if you want to look into it further.
  • Replies 467
:rofl:
Evo was an option but i just don't like them, driven two of my mates mild mod evo 7 and damn are they quick! but i just not a big fan of them.
plus group a gtr look so nice!
Yes i agree they do look nice and are exciting to drive. but if i had an evo i would have alot more races/track days under my belt.
as for the cams i believe i ran some tomei 260 with 9.1mm lift on -5 and they were nice. i'd have to ask my engine builder the exact specs.
Ohh this ia very long and slippery slope my friend, be very careful once you start its hard real hard to stop.
I know this cause i just want a good track car as well............just buy mine lol i have other toys to play with
>_<
i saw your viper build that thing is amazing!
i know its a very slippery slope ahaha! just have to look at my bent :D track gts-t LOL!
On the whole shock topic at your experiane level I rekon I could throw a set of bc coilivers in your car then use the same springs in a set of 18grand penske's and honestly I'd be very suprised if you could determine which shock was which. We've done it with a few guys who have campained state level sedans for a while.
I have a set of Bc's a set of proflex and a set of penske's that will fit a gtr easily if you wanna see what I mean.
Don't waste your money on stupidly expensive shocks just because they are a Jap brand name and expensive.
I'm not recommending you buy bc's either I'm recommending you don't buy something overkill.
I'm sure the serious qld guys would agree if I said have a chat with Murray coote about getting a set of shocks made up to suit your application and budget.
Springs your kidding youself if you rekon 10plus!
Been there Tested that. I'd garantee you'll take a second atleast out of the car with the right springs, even more so if you do get the weight down.
Good to see another gtr being built.
Yeh, speak with Murray. Check bank balance and then be forced to go buy 2nd hand of yahoo auctions :(
Murray's stuff is good value in the grand scheme, and IMO you're better of slashing laptime via great handling versus more horsepower, it just makes more sense.
Having said that, I use a set of Apexi N1 shocks in mine, but one day, oonnnnne day, I'll get some MCA :D
hmm
another question. need to pick my ecu to go with the engine specs (gt-ss aim for 500hp @ engine)
Limited the list down to 2
d-jetro or vipec, i know my tuner loves d-jetro as that is what he sugguest for me to run when i went to saw him yesterday (forgot to ask about vipec)
what are people throughts? cost wise i can get d-jetro for around $1000-$1200 with all the gear, still waiting on price on the vipec
Edited by Kaido_RR
I once read a similar question about ViPec being posted and saw a Vic guys response which wasa picture of the ViPec box being used as a door stop. Harsh, but originally there were some integration problems, I dont think the EBC finction is still working properly. Many have great success, others seem to struggle with needing a few tweaks. But the end result seems great.
Not trying to write off the product, but I think its important to consider as if its not the recommendation of your tuner then it means the time and expense, dyno time etc getting the ECU working is likely to come out of your pocket in tune time. If he tells you to go ViPec then odds are he has his head around the little gremlins and/or wont charge you to flash/fix issues etc
Just pop in to see my tuner to ask about the Vipec, he said he can tune it and has no issue tuning it but for the price he said he rather put an Adaptronic in my car as its alot cheaper and you get similar functions.
However he pretty much sold me on going d-jetro. i have to agree with his reasoning that having the h/c with the knock function allows you to detect problems before they destroy your engine on the track
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
