Hey guys,
Just brought an emagage blue ecu of a forum member.
Can you run a map sensor with it so you dont need an afm?
Or can you upgrade afm and injectors without any hassels or whats the go.
Tried searching but didn't find the answers i was looking for
also where can I buy the injector and ignition harness and boost sensor etc etc from??
https://www.sau.com.au/forums/topic/333329-e-manage-blue-ecu-question/
What tuners is there for the emange ecu fellas??
Im in Mansfield VIC
Etuner or Status, both around Dandenong.
I think you may need the ultimate to run the map sensor but ring them and check. Injectors are a simple before/after value change.
I think Autobarn are Greddy dealers but I would just wire it in if you have the universal loom already, unless you only got the unit. Try importing one?
http://www.etuner.com.au/
http://www.chequeredtuning.com/new/
I have the basic harness man. Thanks for the links. Yeah will have to ring and check it out. I think you can run the map sensor and all not to sure but i think you need the computer software and cable to do it tho. cheers for the help man
