Hello all,
Recently i've had the urge to upgrade my current XFX GTX 285 black edition card to either the GTX 470 or GTX 480.
as stated in another thread, i'm quite weary about touching new cards because of my expierences with my previous XFX GTX 285 black edition ( Fried because of constant 90*c + temps).
my current 285 has a aftermarket air cooling kit fitted that has kept the temps to around the 42*c idle and 49-50*c temp when i'm playing my games.
I'm curious to see if anyone has one of these cards fitted, and what your opinon of them are, what i'm more interested in is what temp they run at idle and temps when they are under load. i dont want to change cards, and then end up having the same problem as my previous fried card later on down the track. i dont have the money, nor patience for that.
i'm not interesed in ATI cards at all. so please dont ask me to change from nvidia :bunny: .
https://www.sau.com.au/forums/topic/333336-gtx-470480-temps-opinions/
Simple good "GTX 460" review, you'll soon seen temps are now under control with that specific card.
Or just read this:
http://www.anandtech.com/show/3809/nvidias...60-the-200-king
Less than 75 degrees @ full load, no worries on stock cooling.
Not a problem at all IMO. a full 10 degrees cooler than the GTS 285.
The GTX 480 IMO, still a no-go, just FAR too hot.
ohh I dunno, one of my workmates has an EVGA overclocked 480, he's overclocked it a bit more, but that's in a HAF X case which has awesome cooling, and the sheer size and heat of it (it burns your fingers after being on for a couple of minutes!), as well as insane power draw puts me well off.
To put it more succinctly, 2x 1gb 460's with a bit of an overclock are going to use less power, generate less heat, and outperform 1 480, for at least 100 dollars less :P if you don't have an SLI capable motherboard well you can either wait to see what high end GF104 based card Nvidia will bring out, go the ATI option, or buy a new motherboard of course!
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
