For sale or swap.
Bilstein struts to suit an R32 GTR. Good condition, no leaks or noises.
$90/pair Pick up Sydney. Call if interested, could arrange postage.
Keen on swapping for an R32 GTR airbox, or an Apexi boost gauge. Also keen on a Nismo quick shifter, with money your way. Anyone? Possibly interested in swapping for other parts. Let me know what you have, give me a call.
Dan
0406 441 672.
https://www.sau.com.au/forums/topic/333398-r32-gtr-bilstein-struts/
Hey man,
Do you know roughly how much lower they (might) sit compared to stock suspension?
Also, whats the cost for postage to Vic, 3170?
Cheers.
G'day champ,
Yeah, I really couldn't tell you for certain. From having a rough measure I believe they are set at factory height. Springs are easily changed though. You could even take 1/3 of a coil off with a grinder without changing the spring rate too much.
The shocks are for sale on twinturbo.com.au at $345 EACH.
I'll post them for you for $25.
Cheers,
Dan
0406 441 672.
Is it on lowered springs? will it it onto a GTS-T r32?
Hi mate,
Yeah, as I said to the other bloke, can't say for certain, but I believe they are at standard ride height.
Yes, they will fit into a GTS-T R32.
Bilstein shocks sell for $345 each new.
Dan
0406 441 672
