By weikleenget · Posted
Hi all, A little back story, my AWD hasn’t been working since the car was taken out of storage but today after changing all the low and high pressure lines and bleeding the system, I was able to get power to the front wheels. Big progress! Issue is that the torque gauge is showing 40-50% in all driving conditions and front wheels are always driving even when the car is on stands. The OE front ABS speed sensors were damaged when we deleted ABS so my mechanic tried fitting some generic speed sensors, which I know are not calibrated the same as the OE. My first question is, does anyone know the part number of front LH/RH speed sensors and if there are any direct replacements besides OE Nissan? Those are apparently made of gold… Also, if power is always going to the front will the transfer case oil overheat, or otherwise will it cause damage? Thanks for the help -
By funkymonkey · Posted
Yeah the order was intentional. I had a mental model of user engagement: new user gets to know their car gets to know their local community gets to know wider community -
Do the oem 360 cameras work well with the system?
Would get the Gktech one then, it's 1 hole which would be straight forward to drill, plus it's a third of the price.span widget
Look on the top of the radiator support panel. ie, look down from there.
