Hey Guys
I am new to this site and my knowledge for skylines only go so far so your help and advice would be much appreciated. I have an option of buying a 1993 R32 GT-R or a 2000 R34 GT-T, they are around the same price. I was just wondering with reason as to why people would take one over the other? If you could list pros and cons that would be great.
Thanks heaps in advance.
https://www.sau.com.au/forums/topic/333407-r32-gt-r-or-r34-gt-t/
try searching SAU
or
in Google type
site:skylinesaustralia.com "what you want to search"
basically R32 GTR is a cult Car as all GTR's
but they are getting very old and can be very very expensive to maintain, specially if you dont know what your looking for
R34 GTT are pretty new and hence will be more modern and Newer, most states you can not own either car with a P plate.
both can be modified and are anyway pretty fast even stock...
GTR will always have lot more following and respect than the its single Turbo RWD brother
Hey Guys
How many kms on the R32 GT-R odo Vernon?
If low, do the seats, carpet, key barrel, bodywork, suspension, bushes, engine, gear changes, dashboard reflect that?
No rust?
Services all done?
Any damage or major repairs?
Taken it to a Skyline specialist workshop for a good lookover for $125 approx?
If all the above is good > GO THE GT-R and come to the Event below!!!
On the other hand, the R34 GT-T is a good step up to the top. No sweat!
Pros of the GT-R
* power to the tarmac is more predictable
* better cornering
* higher speed on sweepers
* can brake later and accelerate earlier through a corner
* overall dynamics
* later models had upgraded brakes - but not sure about 1993
Cons of the R32 GT-R
* if it's old, it has seen better days
* lack of history means a suspect car
  • 1 month later...
  • 11 months later...
when asking the question of "r32 gtr or r34 gt-t" you have to ignore all the fanbois who just blindly say "go the GTR" and ask yourself what you want from the car. if it is going to be driven daily and you just want something with a bit of get up and go, then go the r34. if you want something to drive on the weekend but not on a daily basis, then go the gtr.
speed on straights. they're about the same. raced a friends gtt the other week. he beat me just. i say each to his own. im a nissan nut so i bought the gtr. if ur looking for a skyline just for looks and streetability, go the 34. i get about 3-400km's per tank. and with the coilovers its a rough ride. but i do like the attention i get for owning it. no cops yet (touch wood)
so true man.
No rust?
Services all done?
Pros of the GT-R
* better cornering
* overall dynamics
Hi, do you know if there is any skyline specialist wksp's in sydney pref Liverpool area?
cheers
First up, I don't trust anyone around Lansvale.
Best to use someone who doesn't want to sell you extras and knows their RB engines
To inspect your prospective buy, call
* JapLink at Haberfield 02-9716.0857
* Tunehouse at Marrickville 02-9557.4000
* Just Jap at Kirrawee 02-9545.0532
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
