This is best described using the images below
Found it on Import Monster, didnt bid as I had one ordered from AAIP in QLD, then when it arrived it was the wrong colour, and the auction on IM had closed!
Its the storage compartment lid that is in place of the Navigation controls / TV in models without Navi
The third pic shows why mine needs to be replaced (drill holes!) from the makeshift Navi i pulled out
Like my Paint handiwork??
https://www.sau.com.au/forums/topic/333438-wtb-m35-dash-piece/
  • 1 month later...
Hey do you still need a lid for your box ?
Brett
  • 3 weeks later...
  • 4 weeks later...
where would i be able to buy this part as i have to take out the nav.?
I would like a centre console to replace the bose system, so that I can put a new stereo in.
Please contact me if you have one.
Cheers,
Kym
Hi mate have you replaced Bose your system?
if you have have you still got the original unit?
As my system has just died.
Thanks
Nah haven't replaced it! $850 for new facia put a stop to it.
I'm still looking for one will let you know if I find one.
Damn - so $850 JUST for the new facia right?
I suppose the fact that the stereo and climate control are integrated doesn't help...
Thanks
send me the unit and I'll fix it. is it totally dead?
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
