Before you guys say it (for sale again huh?) lol..
The only reason for this is that I'm going on a long holiday over to Europe to visit my family and do some work for dads company's, and seeing that i will be out of the country for about 3 months + i have decided to sell up to help fund the whole trip as well as pay a few bills before i leave! Was going to have an Rb25 in the engine bay next week but everything has been put off for this!
And to all potential buyers that inspect the car and doubt my reason, i will show you my ticket (which will be purchased by next week)
Anyways on with the sale!
PRICE $10.000 with 6months rego
Make: Nissan
Model: Skyline HCR32
Year: 1993
Odometer: 187.XXXkms
Color: Black
Engine:
Kakimoto Regu 06&R Catback
HPI front pipe
Jjr dump pipe
High flow cat
3A Racing air filter
Splitfire coilpacks
ASI 52mm alloy radiator (to be installed on Saturday)
Suspension & Brakes:
ISC N1 Coilovers
Cusco castor rods
Kazama tie rod ends
Jjr front upper camber arms
R33 Front Lca's
Power spirit rear camber arms
Hicas lock bar + all hicas line removed
Dba cross drilled and slotted front disc's
Dba vented rear disc's
Bendix ultimate pads F&R
Chassis & Clutch:
Excedy HD clutch
Nismo reinforced clutch pedal bracket
GTR front strut brace
Cusco rear strut brace
Wheels & Tyres:
Gramlights 57D 17x9 +22
F Kumho Ku36 235/45R17
R Yokohama Advan R1 235/45R17
Now the car has had a respray, as many of you have seen before it was primered, reason for that was flared guards and cracked paint so i though to get it all painted!
Bonnet and boot lid will be done this coming week, reason i left them out was due to upgrading to carbon but seeing that I'm selling no point to change!
Timing belt, water pump, oil & oil filter change, spark plugs and new alloy radiator will be all done this Saturday 21/08/10
The dashboard is going to be replaced as well due to the old one having afew bubbles & the carpet has been replaced with new black one!
So all in all a lot of stuff has been replaced or upgraded which will save the buyer a lot of money!
If you have any questions please send me a PM =)
Thanks heaps
https://www.sau.com.au/forums/topic/333446-hcr32-4sale/
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
    • Well, it is an unusual noise. Use a 2 foot long bit of garden hose stuck in your ear as a stethoscope to pin it down to a definite location. We'll never work it out across the internet.
