Hey People
wrecking 2 R33 Coupes series 1 and series 2
Series 1: Rb25t 5 speed manual.car has done 140xxxkms,interior,exterior are all standard,engine is also standard just bolt on mods,
GCG high mount exhaust manifold
GT 3540 .063 housing
Power FC
spiltfire coil
Intank bosch 044
greddy copy intake manifold
Yellow side feed injector(500cc)
alloy radiator (just jap)
heavy duty clutch
tomei diff center
coil overs
Series 2:Rb25t (5 speed manual SOLD),Car has done 83 xxxkms and is pretty much standard,all parts available,
3inch dump pipe,3.5 inch cat back kakimoto,
and any standard parts include, interior,exterior ,engine,drive line,suspension
Photos will be up next week,Postage can be arranged for some parts
Located liverpool
0451606199
Edited by yep33
https://www.sau.com.au/forums/topic/333495-wrecking-r33-ser1-and-ser2/
Series 1 is grey in colour
series 2 is red
Injectors and rail $500
Not sure what model kakimoto exhaust it is (how do i tell?)
also in good conditon has had a extra muffler added to it
Best way to contact me it via phone as i wont get a chance to get to a computer this weekend
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
    • Good work. I will say, this line circled however, will potentially pool with oil, as it's going from high, to low, to high, before heading downwards.
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
