: R32 4 DOOR RB30/25 NO MONEY SPARED 415hp 865nm
Condition: Used
Reason for Selling: MOVING
Asking Price: 17000 ono
Delivery Methods: PickUp
Contact Info: 0413203951
Extra Information: will swop for gu patroll or along those lines
Running Autronic SM4 ECU 415hp on 19psi 350hp on 14psi
Custom Respray in Solid Blue inside and out (including engine bay)
Gtr front bar/Bonnet/Grill
Vertex Side skirts and rear Bar, Vanquish Roof Spoiler
hand Flared front Guards,
Gtr Front and read Seats
Custom Tail shaft
Kazz MEchanical 2 way Diff
Cradle spacer Bushes (alloy)
Solid Steering Spacer
Tein Coil overs
Rear Upper Camober arms KTS
Adjustable Castor arms
Nardi Wheel
4 gauges on the dash boost/oil temp/oil presure/water
rebuilt brakes with dba slotted rotters all round
oil coller with gready thermostat
Hicas Lock Bar
Bosch 044 external pump feeds the 680cc injectors from the surge Tank
Gtr in tank lift pump
Hundreds of $$ in speedflow and braided hose
Plumb back Greddy BOV
its a rb25/30 with about 12000km's on it
Custom Exhaust manifoild and 4 inch exhaust
Custom Intake Manifold
Custom Intercooler Piping
Custom Oil Catch can (returns to sump)
Custom Baffeled Sump
PWR 81mm Intercooler
42mm Alloy Radiator
60mm Pro Boost External Wastegate
Garret GT35R 1.06 rear
RB25 Gear box
18inch rims with ku36 up front
Clear timing cover
Spool adjustable Cam Gears
URAS Handbrake Pads
alarm
Edited by wilba
https://www.sau.com.au/forums/topic/333506-r32-4-door-rb3025/
so u say its a 30/25 but you show a pic of the engine bas with a rb26
even has rb26 written on the clear timing belt cover
even has rb26 written on the cam belt cover
well if its a rb25 head and it is mocked up to look like a 26 kudos to u.
one for it looking so dam good and two for being honest.
top effort reminds me so much of my old 32 4dr. similar colour to :ermm:
Edited by sneaky1
  • 6 months later...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
