Fc Rx7 And Zx10r
Kawasaki Ninja 2005 ZX10R
Has only done 5000km and has a full years rego
Is immaculate looks like it just came off the factory floor
Scott/Ohlins steering damper
Akrapovic exhaust
Fender eliminator
Brand new Pirelli diablo supercorsa good tread
Oggy Knobbs
Frame sliders
Remote alarm and light
Rear seat cowl (can be swapped back in a couple of seconds to a two seater)
Ventura travel rack (not on bike i don't use it)
Have most of the stock parts to go with it
$10,000
may swap
$8400 with all the fruit
$7600 no seat/ gauges
or make an offer
88 FC3S RX7 GT-X
jap import 13BT
Grey interior (good condition)
car has 6 months rego
112932 km on the clock
Mods
Fujita Engineering/FEED 60-1 High-Flow turbo
This turbo is very inconspicuous and is rated to 400hp, also has HKS adj. actuator
pressure with full memory recall
Nardi classic wheel
Gear knob
Drift Handbrake Button
Series 5 tail lights
Microtech mtx-8 (just tuned at revs, running very nicely)
Pod filter
Trust bleed valve currently running 8psi (very safe)
Exhaust Technology 3 inch dump, front, high-flow cat and exhaust
New cooling pro intercooler/pipes tested and no boost leaks
Bosch 040 fuel pump
Exedy clutch with lightened flywheel
Shimmed S4 LSD
Rear battery location
Car no longer has AFM due to microtech computer, but still runs OMP
Flared guards
RIMS D1R wheels, Silver/polished lip, 17 x 9 +30 and 17 x 10 +15
TIRES 215/45 Kuhmo KU36 semi comp R and 235/40 Kuhmo P716 Admiral tyres
Both rims and tires are in very good condition and are like practically new
Kei Office Coilovers (10kg/8kg) very stiff
Cusco Tower Bar
Brand new leads and plugs
s5 front bar
gauges and seat will be removed before sale
Extra stock parts
Original driver's seat
Original suspension with king springs
Original turbo
Stock ecu
most parts like vac hoses ect to return car to stock
Pretty much everything i can think of for now
The car has just been to revs and has been compression tested and tuned so it running very nicely , car is always warmed up and cooled down. car gets regular oil changes/ has new plugs. car has also just had a wheel alignment.
problems: only probs are the paint isn't perfect but still looks good, and the cold start needs to be tuned if you care about it (not a problem for me)
Contact: pm me, my mobile is 0431071776 but im not always available
 Share
    • This one isn't "on the street" per se, but it was on the street just prior to the photos being taken..... Mitsuoka Nouera, based on a CL7 Honda Accord. It was in the carpark of the Hanshin Nishinomiya train station "Ebista" shopping mall. I'd say they are very rare compared to other Mitsuoka models.
    • Do the shapes of the rice crisps really conform to the individual car model shapes or is it a bit of a stretch? I mean, do you know you're eating a BNR32 GT-R after having grabbed one from the can? 😁
    • Yeah, pure laziness My main reason for the change is the local crappy roads, car felt great going up the Mac Pass, and then back down the long way home via Jamberoo Mountain Road after ramming a sausage roll and coffee down the gullet  But as stated, good reason to head back down for a pie or sausage roll and coffee  Some nice cars turned up at the pie shop, my fave was a mint V8 Soarer coupe, the condition of it was truly awesome  Edit: plus to adjust the dampening I need to remove the OEM front strut brace, because it covers them, and remove some of the rear boot trim, I did have my little tool kit with everything required to do it with me, but, yeah, laziness
    • Any reason you didn't, like... change it while at the Pie shop so you could compare them on the way back? (all the more reason to go for another drive I suppose)
    • After a lovely little cruise up Mac Pass into Robertson pie shop on the weekend, and all the daily driving on our crappy roads, I decided to soften up the dampers a bit I've gone from 13 clicks from full soft to 9 clicks on the front, and from 8 clicks full soft to 4 clicks on the rear Whilst the car did handle great before, on smooth roads, it was a little bit harsh on pot holes and joins in the road, but only in the rear Also, my uneducated assumption is you need more dampening in the front compared to the rear, hence the front is set a little harder by 5  Will this help the budget spec BC RS coilovers on bumpy roads, I'm hopeful.....
