http://www.youtube.com/watch?v=0RuGajWd_ys
Hi guys,
It's a R33 GTS25T. When it is cold, it idles fine, after 4mins warm up, problem appears(in the video). Sometimes, after 10mins driving, it just getting worse. When i stop at traffic light, rev could drop to 400-500 and start fluctuation between 400-700rpm, and the car shudders. I have to keep the rev at around 1000rpm to prevent stalling, but I can still feel it shudders a bit. The headlights go dim when rev drops, voltage also drops a bit. I checked the alternator belt, it seems still tight. Sometimes the voltage is not stable, changes between 13.9-14.2.
It drives fine, i mean, if i keep the rev higher than 2000, hard to feel any problem. It seems only happens when car is standstill after warmed up.
AFM is good, AAC valve has been cleaned. spark plugs are new.
maybe the O2 sensor? But O2 sensor problem seems worse than this one...
maybe the alternator itself?
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
