Hi guys, looking at purchasing a skyline interstate.
Problem:
Cage firstly (copy paste.. Cusco 6 point roll cage (currently only using 4 point))
Then..
Sard Trigger boost controller
Cusco 1.5 way LSD
Ohlins coil-over suspension (Depends on inspector right?)
Titanium exhaust system (Change to stock?)
6000K HID's (I know these are iffy)
The guy says its 100mm off the ground...
Its also running really wide wheels, so would change to stockies and pump lots of air for some more clearance...
Basically, more hassle than its worth?
Cheers.
Edited by Ten Four
https://www.sau.com.au/forums/topic/333548-pits-would-it-pass/
  • Replies 45
Problem:
Then..
Cusco 1.5 way LSD
Cheers.
Cage - needs engineer's certificate and can only be registered as a 2 seater.
Boost Controller - just hide it
Diff, depends how much it skips
Coilovers, depends on inspector
Exhaust, as long as its got cat, muffler, clears 100mm and under 93? db it's ok
HIDs, again depends on inspector.
Make sure its 100mm WITH your weight in the car, as you actually have to drive over the 100mm height check.
Mm, I could probably source an exhaust as I can't see a titanium one passing lol.
Wouldn't mind the 2 seater thing...
So, its not that bad right?
He said it was imported under low volume imports scheme, so it should have a plate... Also, he imported it himself so I'll assume he has import papers.
Cheers WCC guys :huh:
EDIT: It IS complied.
Edited by Ten Four
I don't think it's that bad man. Just remove the cage, they are gay anyway, somebody wanting to build a race car would probably pay a good bit of coin for it.
The other things aren't hard to fix, standard suspension is easy to find, standard exhaust is easy to find. Really not a big deal.
For a noob like you......yeah it IS bad. :ermm:
What's soo special about this one to justify interstate ... ?
2 Seater rego gives you other options, like fixed back seats and shit, become legal.
My other Ceffy is going to be registered as a 2 seater with cage.....4 door, 2 seater...work that one out.
For the record, only bolt in cages are legal, but you knew that already right ?
"The car has been fully complied and had the plate
fitted. All import paperwork including import
approval is available, so the car can be
registered without much trouble.
The roll cage is a bolt-in Japanese cage so it can
easily be removed within about 10 minutes."
:ermm:
it depends if the inspector says it can be rego'd or not
if it can't be - the inspector will tell you what needs to be done
personally if i was your inspector i'd tell you to lose the cage. you're not impressing anybody. and i'd make you eat your steering wheel and put the original one back on. you know, the one it's SUPPOSED to have. WITH THE AIRBAG.
(no serioulsy - get rid of the toy and put the airbag back on, you'll need that to pass pits. and rightly so)
Its a 1993, I highly doubt it came with an airbag.
My old 1994 R33 didn't.
Cage is there for a reason... Its an ex track car I believe. Everything was done in Japan.
I would change the wheel though, its ugly...
Edited by Ten Four
Guest
