hi guys,
i went to pull my ecu out tonight and 1 bolt is easy as - on the passenger side firewall but its got this cage around it which looks to have tamper proof bolts - threaded bolts with amost flush pop rivet style head.
anyone seen these before
will try and get a pic up tomorrow
thanks
https://www.sau.com.au/forums/topic/333581-r34-gtr-ecu-question/
hi guys,
thanks
Pull cage and all out.
Sorry - assuming its the same as my Stagea where to get the ecu out you unbolt the cradle that holds it even though it looks as though it would slide out of the cradle. Maybe you should post up a pic ?
I think the later R34s (maybe Aug 2000-->) had this security cradle thing. It seems to be specifically designed to stop you removing the ECU.
Starion4me - If you have got a late R34, I remember that when we did get the ECU out, it messed up the built-in Nissan security/immobiliser thing too. Even plugging the stock ECU back in didn't clear it, so we had to short cut the ignition system in the end. Just a word of warning...it may not be the case for yours
ouch - yeah mine is one of the last aug - 2002.....i think i will wait till i get my power fc then....i hope when the time comes i dont have any issues
thanks for the advice DJ Davey G
Hey,
The actual immobilzer for the NATS system the JDM BNR34's are equipped with is inside the factory ecu, that's why they don't want you removing it. If you replace the ECU with something like a VIPEC you'll find you no longer need the coded key to be able to start your engine. The BNR34 Power FC supports the NATS system though, but doesn't need to be recoded to work with the NATS box, like the stock ECU does (if you replace it with another stock ecu it still won't work till you take it to a Nissan dealership and get it recoded).
On another note, you say you want a BNR34 Power FC.. I have one sitting right here out of my car with handunit I'm willing to let go relatively cheaply =)
Cheers,
Markus
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
