For sale is Garret 25/30
I bought it intending to use it but now I want something bigger..I haven't used it yet and bought as second hand-has some shaft play and may need to be rebuilt. Was going to get it looked at to confirm if it needed a rebuilt but now I want bigger so I haven't done so..asking price is $1100 Ono.(considering it may need a rebuild). Inspection welcome
0419837474
https://www.sau.com.au/forums/topic/333583-for-sale-garret-2530/
are you serious mate 1100 for a turbo that possibly needs a rebuild that you can buy brand new for $1300 . BAAAAA HAAAA AHAAAAA
Your actually right-probably shoulda researched this a little better before taking other's advice on what it's worth..I clearly paid too much for this...cheers for the comment dude
Offers on turbs....
actually no you cant for a garrett
however i do think the price is a bit high for one that needs a rebuild
U can get second handys close to 1300, brand new Im not 100% on price-my understanding is they are 1800-2000 range from what I've been told, if someone knows what they are brand new pm me I'd be interested to know..
Offers anyways,no hurry to sell,may end up keeping and getting sent in for inspection-use until I get what I want
Have taken to adelaide turbo service and bill inspected it. He said it does not require a rebuild and is in good condition for a second hand turbo. It Is a hks 25/30 not Garrett as I previous mentioned..the hks use a Garrett front on The 2530. It was previously on another car making 250rwk, but best suits rb20. These normally sell for 1300 second hand and bill also advised that is what mine is worth. So asking price remains $1100 firm.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
