Hey guys,
Brand new to this forum, first ever skyline I have owned for less than a week,
It is a R33 GTS25T, manual
The car drives very well, its very smooth, but over the last couple of days, whilst driving, it randomly stalls. Basically the engine cuts off, I lose power steering and I have to chuck it into neutral and start it up again. The car is idling very smoothly at roughly 600-700rpm, theres no lag or misfiring, turbo kicks in well, nothing what soever unsuaul when driving it normal. I have no idea what is causing it, I am new to turbo cars and nissan skylines in general.
The car is basically stock except the following:
*XS Turbo exhaust
*previous owner had installed a HKS Fuel Cut Defender in 2007
*it has an aftermarket BOV
*K&N pod filter
I've done a search of the forums, but can't seem to find anyone with a similar issue except getting idling and stuff involved.
Any help would really be appreciated as to why this is occuring,
thanks
Is your standard BOV Plumb-back? or is your hose blocked? if its blocked... that could be causing it, your standard ecu isnt tuned for Atmospheric BOV
Edited by geraus
Although it looks more than likely that it's a BOV issue since you got an aftermarket one, I experienced the same stalling problem when I first bought my car because of the AAC valve being ridiculously dirty on the engine. Not sure if that'd be the problem but it's worth a look since it fixed my stalling issue straight away. Here's the link for the DIY info
AAC Valve DIY
Hey guys, thanks for the pointers
took the car to the mechanic to have a quick look at it, he stated engine is healthy and said to bring it back some time this week to get all the pipes cleaned including AFM, AAC. He also increased the idle rpm by roughly 200 or so its idling a touch higher - said to have a drive around and see if this fixes it in the meantime.
So went for a drive, and yes engine shut down again, lost power steering etc. =S
Have been driving it over the weekend abit more, and starting to notice that it has yet to stall on me when I dont touch boost and instead shift at 2500-3000rpm. However did a run with some boost, and a couple minutes later instead of stalling I saw the battery light come up on the dash and lights dimmed as if it was going to shut down but then it went away.
It did the same thing yesterday, didnt shut down but battery light came up, and that was again after i hit some boost.
So I don't know if its coincidence or if its something to do with the air flow whenever I hit boost?? I was reading everywhere on the forums and it appears that there is a big no to atmospheric BOVs, and I'm thinking now to definitely remove that and put the stock one back on.
Maybe that, and cleaning the AFM & AAC may do the job?
Well finally took the car to the mechanic late last week and got the following done to it:
- got the aac cleaned/throttle body
- afm cleaned/tubing
- blocked off existing atmo BOV and connected back the stock BOV
mech said the aac and afm was massively dirty and flithy!
car is running sweet now, has not stalled over the last week which is great, and stock BOV noise sounds so much better than the fully sick whooshes and fluttering i was getting from the previous set up! i do use it as a daily..
but yeh thanks guys for the help, fixing those seemed to have fixed my stalling problem (fingers crossed it has) !
hey how has the fix gone?
I'm like totally in the same boat as you - just got my 97 S2 Gtst a few weeks ago, but only that this has only happened to me just twice.
I hope it worked out well for you because I was worried it was a serious mechanical issue.
And its not nice when you rolling in a parking lot, car is moving, then you gotta restart the car in front of everyone.... :P
Mate check your air flow metre, take it to a spanner put a computer on it, I wasted 700 on other stuff before I did this 1st thing I would do. My car was stalling randomly in any condition I took it to one place they had it for 6hrs and nothin the other place had it in 5min
my two coin
Cam
