Hey guys,
Brand new to this forum, first ever skyline I have owned for less than a week,
It is a R33 GTS25T, manual
The car drives very well, its very smooth, but over the last couple of days, whilst driving, it randomly stalls. Basically the engine cuts off, I lose power steering and I have to chuck it into neutral and start it up again. The car is idling very smoothly at roughly 600-700rpm, theres no lag or misfiring, turbo kicks in well, nothing what soever unsuaul when driving it normal. I have no idea what is causing it, I am new to turbo cars and nissan skylines in general.
The car is basically stock except the following:
*XS Turbo exhaust
*previous owner had installed a HKS Fuel Cut Defender in 2007
*it has an aftermarket BOV
*K&N pod filter
I've done a search of the forums, but can't seem to find anyone with a similar issue except getting idling and stuff involved.
Any help would really be appreciated as to why this is occuring,
thanks
Is your standard BOV Plumb-back? or is your hose blocked? if its blocked... that could be causing it, your standard ecu isnt tuned for Atmospheric BOV
Edited by geraus
Although it looks more than likely that it's a BOV issue since you got an aftermarket one, I experienced the same stalling problem when I first bought my car because of the AAC valve being ridiculously dirty on the engine. Not sure if that'd be the problem but it's worth a look since it fixed my stalling issue straight away. Here's the link for the DIY info
AAC Valve DIY
Hey guys, thanks for the pointers
took the car to the mechanic to have a quick look at it, he stated engine is healthy and said to bring it back some time this week to get all the pipes cleaned including AFM, AAC. He also increased the idle rpm by roughly 200 or so its idling a touch higher - said to have a drive around and see if this fixes it in the meantime.
So went for a drive, and yes engine shut down again, lost power steering etc. =S
Have been driving it over the weekend abit more, and starting to notice that it has yet to stall on me when I dont touch boost and instead shift at 2500-3000rpm. However did a run with some boost, and a couple minutes later instead of stalling I saw the battery light come up on the dash and lights dimmed as if it was going to shut down but then it went away.
It did the same thing yesterday, didnt shut down but battery light came up, and that was again after i hit some boost.
So I don't know if its coincidence or if its something to do with the air flow whenever I hit boost?? I was reading everywhere on the forums and it appears that there is a big no to atmospheric BOVs, and I'm thinking now to definitely remove that and put the stock one back on.
Maybe that, and cleaning the AFM & AAC may do the job?
Well finally took the car to the mechanic late last week and got the following done to it:
- got the aac cleaned/throttle body
- afm cleaned/tubing
- blocked off existing atmo BOV and connected back the stock BOV
mech said the aac and afm was massively dirty and flithy!
car is running sweet now, has not stalled over the last week which is great, and stock BOV noise sounds so much better than the fully sick whooshes and fluttering i was getting from the previous set up! i do use it as a daily..
but yeh thanks guys for the help, fixing those seemed to have fixed my stalling problem (fingers crossed it has) !
hey how has the fix gone?
I'm like totally in the same boat as you - just got my 97 S2 Gtst a few weeks ago, but only that this has only happened to me just twice.
I hope it worked out well for you because I was worried it was a serious mechanical issue.
And its not nice when you rolling in a parking lot, car is moving, then you gotta restart the car in front of everyone.... :P
Mate check your air flow metre, take it to a spanner put a computer on it, I wasted 700 on other stuff before I did this 1st thing I would do. My car was stalling randomly in any condition I took it to one place they had it for 6hrs and nothin the other place had it in 5min
my two coin
Cam
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
