Does anyone else in Melb have the 60th Anniversary Edition 32?
One of the many...
i always wondered what the difference was between them and the normal 32 GTSTs but never bothered to look it up.
If you have the original key it actually says on it plus it came with the "GTR" style interior rather than the usual cloth.
the page didnt thranslate too well but this is what it said :mad:
"R32GTS-t only manufacturer limited car. It sells as the NISSAN establishment 60th anniversary commemoration car. The bumper pad fog lamp high mount stop lamp attaching ria jauntily Ra SFHC GT - the same エクセーヌ interior as R & the seat (form GTS system) the private key holder etc."
some more useless information but i found it interesting :D
  • Replies 59
nope thats yet another of the many special editions that were released by nissan.
theres so many special edition releases for the R32 its not funny.
http://www.fullboost.com.au/cars/readersca.../gtst_nick.html - rofl i just realised thats the car i was bagging in the SPOTTED thread :P cause it looked like a GTS but had the R badge on the back hahaha i see it all the time at crown.
lol nark that guy lives at the end of my court, they have also had an assortment of vl's etc lol he sold it a while back
I have a V Selection 2 GTS, which is the one that came out after the 60th anniversry edition (also known as V Selection 1 edition)
Page 2:
Translation:
R32 GTE V Selection 60th anniversary equipment
Commemoratory Key
Gold GT Badges
"High Class" cloth trim on seats
15 by 6" alloy wheel (chrome Polish) +205/60 R15 tyres
Page 3:
Translation:
R32 GTS V Selection 60th anniversary equipment
Commemoratory Key
Gold GT Badges
Rear Spoiler (with LED high mount brake lamp)
Leather sports steering wheel (aka GTR steering wheel)
Projector headlamp (aka GTR headlamps)
Fog lamps in bumper
15 by 6" alloy rims
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
