Hey guys, i recieved my hks ssqv bov today, put it on, and its causing a shitload of chatter.
I dont get it, its a full atmospheric valve, why is it doing this?
I cant open the valve manually all the time, it will go from being able to be pushed open by fingers, to being "stuck" and feels like its hitting something????
Any help????
https://www.sau.com.au/forums/topic/333692-bov-problem/
pull it apart and have a look? pretty sure the SSQV are fairly simple, most BOV's are. Just make sure you remember where everything goes and oil it before re-assembling. It shouldnt be hitting anything if you just got it unless something has come dislodged inside
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409275
the screw on the back of it, loosen the lock nut and then adjust that, mine was way tight and pretty much surged all the time, also your length of intercooler piping and may make a difference and i also found that where my wastegate actuator line was coming from made a difference EG standard spot, big surge so i drilled and tapped into the boost pipe right after the turbo and it surged less
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409829
Is the fact im only running 9 psi going to make a difference??
The little pink pin slightly opens, but the rest of seal barely moves, the stock bov is louder than this one
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409843
they are meant to work in two stages but 9psi should be enough to open it fully, is the signal line going to it coming from your manifold (after the throttle body)
its in the exact same location as where the stock bov was, same vacuum line aswell. if i rev it and push the valve with my finger, its very loud, what i was expecting it to do normally. I took it apart today, moved the spring around and i am able to push it in now. But its as if the second stage is just way to weak to open properly.
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409854
it wont be loud if your just free revving it as no load on motor = not much boost when free rev.
take it for a spin, even take a spanner and adjust it on the road, until you are happy with it, it was said before and im sure you know now you have rebuild it they are pretty simple so no much can go wrong, im pretty sure that if the adjusting screw is out then it causes more surge and if its screwd in then you will have less of a surge but dont take my word for it it has been a long time since i have adjusted mine, good luck
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409867
Thanks for your help mate, one last question, wheres the adjusting screw??
This is the bov below
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409871
that style (the newer one) is not adjustable and works of pressures, if you have lubed up the seat and the valve moves freely now take it for a drive and see what you think, if not then im sorry i was thinking you had the other type.
sorry again and good luck
https://www.sau.com.au/forums/topic/333692-bov-problem/#findComment-5409882
