Thanks Disco! Yeah all of that is definitely what I would like to happen, as I completely agree that a separate dump/front is a lot better - only problem is finding one. the only separate dump I could find on JJR (which is as far as I've been able to search so far) is a HPI one for $500 ish...
I won't make any decisions until I've spoke to my tuner and had his advice on what to buy and where from given to me, as the main reason I want something ASAP is so I don't screw him around any more.
I went for the 1 peice SS split dump from AM Performance here in Adelaide. Beautiful, high quality construction and it does not foul waste gate flap and cause boost spiking. I bought his hi flow 3" cat too at around $600 for both from memory.
Do a search on the forums, I don't think Andrew has one unhappy customer. Andrew: 0401865373
A used HKS one would be an excellent option, I saw a few on yahoo japan and local egay lately.
While I do agree with disco to the 2 piece affair, I did just removed my stock turbo and 1 piece dump from my own car. I actually was able to remove the dump quite easily with minimal stress. I simply unbolted it from the cat then unbolted it from the turbo and slid it out. There was no magic to it, it was just a well constructed item that had plenty of access clearance for the dump flange bolts.
And now for a shameless plug: the item is now for sale :touch: I am looking to swap it for a half piece like what came off your car Trozzle. PM me if you want to do a straight swap or even cash your way (depending on quality of your item).
Cheers,
My dump is stock, so I don't think you want it :touch: 2.5" mild steel, seen 17 years of (ab)use
How much would you want for yours? I'd need to get it posted down to Canberra though, so not sure if you're keen to stuff around with that. Also what size is yours and what power you making with it?
I just spoke to the tuner though, he said they'd be fine to source an appropriate part for me if needed. More or less my only concern here is that I don't stuff them around and waste their time. As long as they're happy with what's going on, then I'm happy.
Mine is an 80mm one piece front and dump.
And id be wanting your front pipe, not ur dump pipe lol. The bit that goes from the stock dump to the cat. PM me what size the inlet and outlet is, and I can more than likely post the item to you if we agree to do the deal.
Im wanting a pipe that is 70-80mm at both flanges, no less than 70mm. As stated, PM me.
ah ok. Well if you can hold out a little bit (by all means keep looking for something anyway, don't wait for me) until wednesday when the car will be looked at etc at the workshop, I can tell you if that will work. I will admit, I'm fairly ignorant as to what is ACTUALLY on there, and whether or not the cat is flanged or slip/weld on to the front pipe. Especially considering I thought it had an AM dump, and it's now stock, I'm not making any more assumptions lol.
Otherwise, if it will work with the workshop, and what I currently have in the way of a front pipe is what you're after (3.5", and flanged at the cat - 3.5" flange) I'm keen to do a swap with you.
lol no problem. 3" is actually 75mm and I only need that the flanges are no less than 70mm. My pipe is off the car and I wont be needing it back on any time soon, I dont drive it. No rush.
Ill go down to the post office and ask them about postage, PM me your details for an accurate quote.
This.
Andrew's level of workmanship is mindblowing... he will custom make anything that you request and it will last the life of the car unlike anything in mild steel. AM performance backs all his products and if they ever fail due to workmanship defects he will repair no worries.
Heres a pic of a GTiR kit he makes and sells worldwide. fits in all factory location and clears everything.
Tried calling him but no answer.
Any idea how much I'd probably be looking at for a 3.5" bellmouth dump from him? I'll wait until workshop gives me exact measurements for the flange etc before I go buying anything though.
For the power levels you're seeking I dont think you need a 3.5' bellmouth... Simply get a JJR 3" stainless dump/fornt pipe and bolt the f**ker in place! Worked a treat on my r33 gtst and I was at 235rwkw on 14psi with a lesser turbo than yours without any restriction.
if he doesnt answer the phone he's most likely working.. he's a one man operation atm. leave a sms with him or email on [email protected]
Any exhaust place should be able to make you a 3 inch bellmouth using the flange of your standard dump pipe. That's what they did with mine and it came up a treat, there's nothing that special to dump pipes, in the end it's just a hollow piece of metal (above workmanship does look nice though)! 3" is plenty for what you are after, why give up the backpressure for unnecessary size?
backpressure is never a good thing, the bigger the better when it comes to turbo exhausts, always! Obviously to a point though, a 5" dump isn't going to be of benefit.
Edited by Rolls
Yeah it all makes sense, I just don't want to shoot myself in the foot all because I'm rushing it a little. Thanks for all the advice though, at this stage the JJR one does look to be the most appropriate, as it's cheap, large enough for what I'm after, and bolts right up. Still leaving final advice to tuner of course tho :blush:
As always, thanks again guys :wub:
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
