Some pricks stole my carbon B-Pillars AND my rear center licence plate light - RIGHT in front of my house! I'm pissed off... What do you guys use to permanently attach these things?
And yes, I need B-Pillars and a rear rear center licence plate light (R34). Anyone who's in Melbourne and have these items for sale, please let me know ASAP 0411 389 062.
LOL, I think the person that stole it must have got a R34 as well, because I'm pretty sure that a normal person wouldn't really know the way how the B-pillars comes off.
Sorry to hear it got stolen tho :(
lol owned.. thieving c*nts! what suburb do you live in? did yours have nismo carbon fibre stick on covers? and who steals a number plate light??? jeez... cheap bastards!
i had one of my b-pillar plastic bits fly off as i was on the track at sandown... $110 to replace from nissan. i used double sided tape to make sure it stayed on. but a thief could still rip it off, so maybe try sticking it on with superglue if you're sure you wont ever need to remove it :( Maybe whoever stole it had one of theirs fly off and they didn't want to pay to replace it
GTTR34, I'm in Hoppers Crossing! When I woke up to vote at about 9AM, it was still there. Got back home and it was gone :(
$110 to replace from Nissan? That's pretty cheap for originals! Did they have to order them in?
I'm worried to drive the GTT at night cause cops these days are tight. Getting pulled over for a "broken" licence plate light (which is missing) is not what I'm after :(
Edited by theponyremark
I'll give them a call first thing in the morning, thanks GTTR34 :(
blk94r33, would Sikaflex work? If not, looks like I gotta grab some Windscreen Sealant :(
If you put Sikaflex on it you will never get it off again. But maybe that is what you what by the sounds of it.
Do a police report and if you get pulled over show them the report and tell them that nissan have to order them from japan and your waiting for it to arrive, should give you some breathing room.
Sikaflex is basically the same stuff, so yeah it'd work, and g35me is right, good luck getting it off if you ever need to... :)
lol dude the chances of the same person losing the same parts is pretty slim so next time they are more likely to steal something else that they need rather then the same thing, so u cant really stick it on there so it can never come off haha, maybe if u do that with everything in your car
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
