Hi got some bits and pieces to clear
located melb se
can post
1 x Z32 Air flow meter VGC $90
1 x Z32 front indicator VGC $40
1 x Z32 front light parker VGC $50
1 x Z32 starter motor VGC $40
1 x Z32 alternator VGC $40
1 x R32 R33 copy 400r front bar needs repaint $40
1 x R32 standard intercooler with pipes $30
thanks
stuart 0448 834 883
located melb se
can post
thanks
stuart 0448 834 883
no time wasters please
located melb se
can post
thanks
stuart 0448 834 883
intercooler sold
located melb se
can post
thanks
stuart 0448 834 883
still got most stuff including AFM
