hi everyone,
i have a harsh airflow drop after ~6300 rpm, at aproximately ~4,4v at Z32 MAF. It feels like i just lift foot of the pedal. When i look at the Datalogit charts i can see that the airflow drops earlier than boost.
I suspected the stock rubber suction pipe being sucked inside under boost and just changed it to a silicon type ebay item enforced with metal rings. I also changed the air filter to the new apexi panel filter in the stock box. but no use.
the cars still shuts after ~6300 rpm.
what else can it be? some kind of full-throttle compressor surge or what? is there any way to diagnose suction pipe sucking itself on the road without a dyno?
p.s. it`s rb25 with rb26 crank and rb26 forgies, hks 256/8,8 cams and GT2871R (without port shroud) running 0.8 - 1 bar boost.
thanks.
https://www.sau.com.au/forums/topic/333769-the-car-shuts-after-6000-rpm/
Check exhaust? does boost drop off? timing etc.
boost drops _after_ airflow.
timing is ok.
exhaust... it`s a split dump pipe from ebay, frontpipe + decat pipe in one piece and fujitsubo exhaiust. the only new part is a splitdump but it seems ok. how should i check it?
and one more thing: usually the first run at is ok -- the car pulls ok to the redline. but other runs at 1 bar have this problem. On very hot days after traffic the problem appears even at 0.8bar.
i had a very similar problem and it turned out to be bad coils. gets worse as you run more boost, and the sudden drop is very violent, mine also performed slightly better in colder conditions.. if its the coils then you run the risk of doing damage to your bearings if you continue to drive it like this. whatever it is, stay off the boost/revs until its fixed
Knock sensors, you get 1 rev to red line then it will retard once its gets to a certain rpm untill the ignition is turned off then back on.
to check this, just turn engine off while moving then turn on again and rev right through to red line to see if its gone and then returns
on next gear rev to red line.
Faulty AFM?
Try swapping with another.
but what is it`s fault? its voltage is ok. it`s voltage drop is ok too as it follows real "pedal lift" effect. but thanks for advise - i`ll try to find another z32 afm.
ok let me ask in other way: is there anyone here running gt2871r or smth similar on rb25 with the stock rubber suction pipe (or silicon type from perfomancewise) and stock airbox? do you have any issues like written above?
thank you.
I think your on the money already. The intake pipe sucks in easier when its hot. I fixed this issue temporarily with some coat hanger wire wrapped around the intake pipe to keep it circular. The silicon intake pipe without rings fixed it and flows better. this was on a Rb25 with GT2835.
Edited by BoostdR
thank you.
Yep HKS GTRS on S2 Stagea with K&N filter. The cut and insert solid pipe per rev210 and issue gone.
You still need to be mindful that the filter can be a restriction causing the pipe walls to suck in so the filter should be cleaned if dirty or replaced as needed.
yes, thanks, as i wrote new apexi panel filter was just installed.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
