So I was doing an oil and filter change yesterday, and this thing came out stuck to the magnetic sump plug: :(
What is it, and should I be worried? Can I keep driving the car?
Possibly (part of) an oil squirter?
What is involved in fixing it?
Engine is an RB25DET, NEO block and S1 head
https://www.sau.com.au/forums/topic/333774-what-have-i-broken/
Hey,
That does look like an oil squirter and if so its not good, if you continue to drive since that has come off the piston will start to develop hot spots as the underside of the piston is no longer getting cooled and ping off its head.
The engine needs to be pulled apart to get at it, I am going through the same problem except mine was due to incorrect clearences when it was being re-built http://www.skylinesaustralia.com/forums/Sn...58#entry5396958
is that seroiusly an oil squirter ? what holds it in? which bit of it squirts . looks like the end off an oil can . even then its a bit crude
and it looks nothing like the other ones in the link above . or any i have ever seen
Edited by lachlanw
LachlanW i reckon it looks like the end of an oxy torch lol. let us know how you go as i want to know how hard it is to change this (IE in car or engine out)
good luck with it i would get squirters to suit your block
i have seen this a couple of times on the forums, is it a common thing? what causes it?
I have no idea how common it is, but it is seems it is either caused by the piston being installed backwards, or the clearance between the piston and the squirter being incorrect, either one causes the piston to hit the squirter and break it.
Yeah, I looked up the part number in fast (NEO ones are different to all other 20/25 :P) and a bit of googling found the following picture:
It's not the best picture, but to me its clearly the same thing.
Unfortunately they are approx 75 bux a pop trade price, and have to come from japan, couldn't give me an ETA :(.
One of my mates has a 25 on a stand atm, so I'm going round this arvo to have a look and try and get an idea of how hard it will be to change in car. If it's too hard, I might just not bother :)
Sprints on Sunday, it won't be fixed by then, so it might blow up and save me having to worry about it ;). A 25 short motor can't be worth too much these days...
banjo bolt is still in, pressure shouldn't have changed. It's broken remember, not come undone. It should just be spraying water oil across the bore, not up to the bottom of the piston
We'll see how we go...
Edited by Smity42
banjo bolt is still in, pressure shouldn't have changed. It's broken remember, not come undone. It should just be spraying water across the bore, not up to the bottom of the piston
You mean oil... :P
I wouldn't run it but that's me.
Edited by James_03
I'm pretty sure the oil squirters are to keep the piston temps down, not so much for lubrication, so as long as your combustion temps are ok and your tune is safe, shouldn't have too much of a problem!
Still, Nissan put them in there for a reason...
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
